nfusion770
- Jul 30, 2006
I disagree- cold turkey is the only way to go IMO. Its not something you need-like food- its something that many people live perfectly happy lives without. The key to Allan Carrs book (I am not trying to sell it, but after 4 years (without smokes) and many rides on the rollercoaster before that, I am still amazed that something so simple works), is that he basically makes you despise cigarettes for making you need them. After this simple rationalization is programmed into your brain (you already know it, you just never thought of it quite like this before) your desire for a cigarette actually reinforces your resolve to not have one. It is really pretty amazing that you use your traditional weak moments as fuel to "kill" the addiction in your life.
In any case- I dont think prolonging your intake of nicotine helps you at all, it just protracts the period of actual addiction. Protracting that period just gives you a longer time to hold off a weak moment.
Anyway, I know about 10 people who quit after reading this book- not the wife, though- she is too stubborn to read it- thus the latest drug.
She is doing great today, by the way, she claims she is calm and doesnt really think about it, other than the "finishing dinner and feeling something is missing" kind of stuff.
Sincere good luck to all of you have decided to quit.
Originally Posted by 1967cutlass I'm not going to stop smoking! Sorry. I don't think you should stop smoking cold turkey. I'll explain. Most of the reason it's a problem is because you're smoking cigarettes. Cigarettes have a high nicotine content, tons of chemicals, are expensive, &c... They are the FAST FOOD of tobacco. There are plenty of other forms of tobacco that are more enjoyable to smoke and aren't as bad for you. Mostly what I have in mind is pipe tobacco. Pipe tobacco is very natural and isn't full of chemicals, it smells and tastes good, is inexpensive, and you DO NOT inhale pipe tobacco. You will get your nicotine so you don't get cranky or irritated, but you won't have the issue of poison being sucked into your lungs. Sure, it's not "good" for you, but it's certainly better than cigarettes, and it's only marginally addictive since you don't generally chain-smoke bowls of pipe tobacco. A well packed bowl of pipe tobacco will last 45+ minutes, that's long enough to sit and relax and have your fix. Just try that a few times a day. It'll make the loss of cigarettes significantly easier to deal with, then eventually you can just quit pipe tobacco, which I guaruntee is easy. I smoked consistently for a whole summer, then once I got to school, just dropped it like that. You can also consider cigars, which are more expensive, or even a hookah, which is too exotic for most people, but it does give an AMAZING smoking exprience. Feel free to agree or disagree with me. |
