Lou Erickson
- Aug 6, 2003
You've all got me eyeing an O2 now. I knew I should have quit reading.
![smily_headphones1.gif](http://www.head-fi.org/forums/images/smilies/smily_headphones1.gif)
Originally Posted by krmathis /img/forum/go_quote.gif You definitely can not go wrong with an SR-007(BL) and a nice energizer. Alternatively a transformer and speaker amplifier. It will most certainly do some damage to your wallet, but on the positive side it should cure upgraditis for a long time. Best wishes! ![]() |
Originally Posted by kelvinz /img/forum/go_quote.gif does the BL make a difference? |
Originally Posted by Dinan /img/forum/go_quote.gif You are kidding?! I need to get a pair. The only problem is how to run it off a Pro Bias amp as I would want to use the same energizer as my O2. Anyway, I was blown away by the performance of these. Not enough to make me want to get rid of my O2's but enough to make me want to have the Lambda around for a spare. Looks like I will have to stand in line for a nice used pair. |
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif I thought most of the Stax amps could all do pro and normal bias, so the 717 doesn't? I never bothered to really check. |
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif Spritzer however did show in a post a while back how to refurbish brown pads with new foam. |
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif The Mk2 are also black, so be careful because it wont sound as good unless you like forward mids and a little added flavor. |
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif The BL is a O2 Mk1 that is black instead of champagne metal/brown pads, and Mk1 sounds better than Mk2. The Mk2 are also black, so be careful because it wont sound as good unless you like forward mids and a little added flavor. |
Originally Posted by mopps /img/forum/go_quote.gif Maybe I misunderstand your definition of "forward mids". But with forward mids I would only put the upper mids (presence) of my former 303 and the upper mids/lower highs (brilliance) of my 4070 into bad context, which seem somewhat overemphasized. But not at all my 007A, it has very recessed mids IME. To me there is not a whit forwardness, unfortunately. Maybe you are talking of the upper bass and key note? Yes, it is somewhat bloated indeed. But this seems only to appear with the wrong amp (SRM-007tA e. g.). With the SRM-727A (best in "direct mode" with a good pre-amp) the bloated bass has largely disappeared. Unfortunately the recessed mids persist. ![]() ![]() |
Originally Posted by WilCox /img/forum/go_quote.gif Actually, the SR-007BL has champagne metal with black pads and headband so it looks quite different from the newer Mk2. ![]() ![]() Keeping these various Stax models straight can be confusing. ![]() |
Originally Posted by charliex /img/forum/go_quote.gif I want to thank all the Head-Fiers that helped me with this purchase. I ended up getting a minty pair of SR-Lambda (normal bias), paired with an SRM-1/Mk 2, and am VERY VERY happy. They're the clearest sounding headphones I've heard. Vocals are warm, clear and clean, the highs are crisp and fast. The bass is full and rich. It does lack the speed of a dynamic headphone at times...but it can go quite deep on some recordings, and is quite satisfying and non-fatigueing. The sheer speed and musicality make these my most turned to cans to date. Looks like I've reached my audio nirvana for awhile. I simply can't afford the mega dollar jump to O2's just yet (still have a family to feed). I've got my HF-2's to turn to when in the dynamic mood, yet find myself spending far more time these days with my now beloved SR-Lambda's. ![]() |
