- Jun 20, 2010
215 width x 230 depth x 80 mm height not including knob.
It likely falls in a pretty narrow niche among electrostatic owners. It's a compact DAC/amp that only serves Stax-plug headphones and has no line or parallel outputs, so it can only be an endpoint or a standalone unit, not an intermediary or source component in a chain. While it's a nice, small desktop unit, most people who are into Stax are already pretty deep in the audiophile game and most likely have their own DACs and sources and plenty of space for larger, higher-power amps. And if you wanted a portable amp, the D10 fills that niche while the D50 doesn't. It's also pretty expensive, and you're mainly paying for the form factor and DAC (using a chip that's over a decade old) over something like the 353X. So if you already have a DAC you like, and either a media rack or plenty of desktop space, there's not much to recommend the D50 over a dedicated amp.I am surprised that the D50 isn’t more popular.
Same. This device deserve more exposure !I am surprised that the D50 isn’t more popular.
According to this review, the D50 will do in a pinch. Probably not optimal for the X9000, but it works.Anyone know if D50 would be able to drive Stax-x9000
The D70s has a line out voltage of 2.5V, which is higher than the consumer standard of 2V. Maybe the VU meter wasn't designed for input voltages that high? If you reduce the input level and raise the amp's volume to compensate, does the clipping go away?Anyone have an issue with the VU meter clipping? I mean clipping in the most literal sense possible: it strikes the right-hand side of the dial range, making an annoying ticking sound. This only happens when I drive them off of a (line level!) DAC (Topping D70s, FWIW).
It also seems to happen gradually more frequently with age.
Holy cow, great investigating skills here — I was foolishly over here thinking line level was line level. That's gotta be it.The D70s has a line out voltage of 2.5V, which is higher than the consumer standard of 2V. Maybe the VU meter wasn't designed for input voltages that high? If you reduce the input level and raise the amp's volume to compensate, does the clipping go away?
Some DAC manufacturers like to have higher-than-normal line levels since it improves SNR. Since noise in the circuit is generally a constant level, the higher the signal, the bigger the difference between it and the noise level, so the SNR improves. It's a bit like stat-padding IMO, but it's a relatively common practice. Also, the measurement gear like the APx analyzers often have max input SNR at around 2.5V, so that eeks out another 1 dB or so in the SNR measurement.I was foolishly over here thinking line level was line level.
