I found a pair of l300 Limited, and was able to borrow a 353x from my father until I decide on an energizer. Going from an Allo Digione Signature to the Chord Qutest, then out to the energizer has pretty much ruined me for all of my other headphones. It's just so beautiful sounding that most of my other gear is going up for sale. I was also lucky enough to borrow L700's and really get a chance to compare the two. (With stock configuration as well as the l300 limited with the l700 pads, and headband.) There's no doubt the L700 is better (wider and deeper soundstage, better treble extension. I've often heard setups referred to as "effortless" and never really understood what they meant until I heard the L700. As much as I like the L700, I didn't think they were as big of a jump over the L300 Limited to justify the price difference for my personal use. (I can always upgrade later down the road if I change my mind). I am certainly buying the L700 pads and headband as I find them a lot more comfortable. (In fact, it's so light that I don't even feel like I'm wearing headphones other than seeing the cable coming from my head.)
I don't really listen at high volume levels (usually between 2.5 to 4 max on the level, or 9:30 to 11 o'clock) and was wondering if I could get opinions on a good energizer. The 353x definitely sounds nice to me, and I am considering buying it for my setup. I'm looking in the 1000-2000 range max. (I'd like to spend less if possible, but if it's REALLY worth it I'm willing to skip a few lunches
). I listen to very dynamic music so whatever I get has to be able to handle the voltage swings. (I'm not sure if listening at a lower volume level means I simply should stick with the lower end energizers or treat this like a normal amp and just get as much headroom as I can afford.) Any thoughts?
