JimL11
I also wonder if a heat increase might panic Stax as they need to fulfil CE approval across multiple countries? Not sure how that works re country regulation for hot devices.
They do seem set on a tube inside the chassis design if they follow existing convention. Even the mighty T2 was all enclosed and look at the heat issues that had.....
TBH they have to equal the KGST I would say to be a realistic amp to drive the 007 and 009 really well re power and sound quality. But if they do that, it would IMO show the general buying public at the various dealers and demo rooms just how damn good the 007 and 009 really are when driven well.
The increase in heat would only be about a watt per side. They already have heat sinks large enough in the 717/727 amps.
