Discussion on usenet in 1994 on headphones by audio engineers Bob Katz and Gabe Wiener:
Katz: "If you're mixing anything pop (e.g. multi-miked), then you can't
effectively use headphones, period. Have to use speakers. For classical
music, I have learned to adapt to Stax SRD-5's (yes, the SRX were great).
None of the Stax so-called "Pro" or "Lambda" are suitable for recording,
while they may be good for home listeners, the coloration caused by the
cavity bounce makes them unsuitable for recording. "
Wiener:"I was at one of the high-end audio dealers a while ago and they were
trying to hard-sell the Stax Lambda phones, rambling on about how
accurate they are, and how Dorian uses them, etc etc. I put on one of
my CDs, listened for two minutes, and then resolved never to listen to
them again. I don't know _what_ they were doing to my recording, but
the result was far from accurate.
Another frightening phenomenon is the Grado HP-1 phones, which have a
bizarre habit of making anything sound pretty good. The danger here
is that if you rely on these phones, they will make you think that
things are okay when they really are not. More than one engineer has
ruined a recording by depending on these phones.
The 7506 is fairly standard for live concerts inasmuch as it is closed
ear, which is important if you're in the same room as the musicians.
In separate control room situations, I've used the Sennheiser 540s for
quite a few recordings and have been reasonably pleased. The 560s
have always been too bright for me to take seriously. The 580s are my
current choice for phones.
Anyone want to try to talk Stax into bringing the SR-X back? "
