fat pat
- Nov 24, 2006
a synchro is a device that matches transmission speed to engine speed, thus eliminating the need to double clutch, it makes it so shifting is easier on the driver, and shifts can be made much faster and smoother
double clutching is when you are shifting from one gear to another, push in the clutch, release the car from the gear, disengage the clutch, so the transmission is connected to the motor in neutral, when revs fall to where they would be in the next gear, you re-engage the clutch, and put it into the next gear. this is for use on older, non-synchronized transmissions, and really has no use in modern trannies
short throw shifters change the fulcrum point of the shifter, to make shifts shorter, they also require more effort. which is why most arent included in factory shifters. most traditional stick drivers arent too woried about sporty driving, and a smoother, longer throw is easier for them.
and shifter preciceness has alot to do with the base of shifter mount, where the transmission is located(rear wheel drive cars are traditionally tighter than front wheel) and the type of transmision it is. a tighter shifter generally transmits more vibraton through the shifter to the driver, which most people will find unenjoyable. this is not always the case however, as with some mazda transmissions, and bmw transmissions.
Originally Posted by pne /img/forum/go_quote.gif can someone explain to me exactly what auto and manual synch gearboxes are? I have a vague idea it involves matching transmission speed to engine speed but the whole process is over my head. Also, how does double clutching work? I know the procedure but what is it supposed to achieve that standard clutch manipulation can't? What is the big deal with short shifters? Is their sole purpose just to make the lever travel shorter? Why don't cars just come with short lever throws in the first place? Finally, every single manual I've driven has absolutely terrible feel at the lever. It feels like you're wobbling a stick in mud. Is there any reason why they are not more precise? This is based on a comparison to a motorcycle shift mechanism, which is smooth and accurate, with a sharp *snick* each time you change gears. In a cars shifter there is so much free play and wobble, and it doesn't help that most of the time you are wobbling around the needlessly thick cover that seemingly serves no purpose but to make the action feel even worse. |
