Slater
Okay, you got me! I’m curious. Can you link the magnets that you bought on Ali? So many magnets on there, it’s hard to choose. It would help me if you could link to a trusted seller of magnets that you are satisfied with. I’d like to try these with my pair of Sony Z7 which would seem to benefit from this mod. I’ll post my results and give you all the credit!![]()
So I thought about this more, and while I can't guarantee a size that fits with the Sony Z7, I have found that a "safe" size of magnet that works for most drivers is the following:
- For 40mm drivers, 12mmx4mm round neodymium N50 magnet with hole works for a lot of drivers.
- For 50mm drivers, 15mmx5mm round neodymium N50 magnet with hole works for a lot of drivers.
I always get the N50 or N52 strength (which is the strongest gauss rating). If a seller or listing doesn't specifically list the N rating, I skip that seller.
I've got them from numerous sellers, and have never really had a problem. It's not like there's counterfeits. So I would say just get them from whomever you want. I've used Aliexpress, Gearbest, ebay, and Amazon in the past.
If you need to know what to search for on those sites, searching for something like "round neodymium magnets hole" is a surefire bet. Then look through the listings to find the size you need.
Depending on the size in the cup, you can get away with a larger or thicker size (for example, a 15mmx10mm). But be aware that often the thicker magnets are sometimes lower gauss, so you're not really gaining anything by getting a 15x10 N35 over a 15x5 N52. In that case, I would go with the more compact but stronger magnet.
The other advantage of sticking with the sizes I listed (12x4mm, 15x5mm) is that you can stack up 2 if you want, creating your own 15x10mm N52 for example. Note stacking 2 doesn't exactly double the gauss rating due to losses I mentioned in the very 1st post. Stacking up 2 will provide a 169% gauss increase, not a 200% increase (but it's still powerful as heck).
Again, the BEST solution would be to open up your headphone cups and measure the stock magnet to find out the biggest diameter magnet that will fit.
Hope that helps.
