alexdemaet
(here's another update)
Would you have any suggestions/tips/corrections on the order of connection and how to connect the devices:
1) connecting Squeezebox Duet with Stello DA220 Mk II DAC (I would use digital coaxial to bypass the Duet dac),
2) connecting Stello dac with HeadRoom Balanced Home (pre)amp (I would use Hovland G3 balanced XLR ic's)
3) connecting HeadRoom amp with Red Wine Audio Signature 30.2 (I would use Cardas Quadlink 5c rca ic's)
Would I need a need a high-end digital coaxial cable to connect the Duet with the Stello dac (currently I have a
QED Qunex P75 Coaxial Cable (http://www.play.com/Electronics/Elec...e/Product.html) which is 50 cm in length? Would I need better RCA ic's to connect the HeadRoom amp with
the Signature 30.2 amp (like for example a Cardas Neutral Reference rca)?
