- Aug 2, 2014
Mailman failing to re-attempt delivery or something else?
Basically. I sent it priority mail 2-day 18 freaking days ago and this is where we are at now:
I see. Hopefully Grizzleybeast can get another. That's why I wanted to give him a way out from getting another from the vendor. Good luck with USPS.
Any more impressions on the amplifier?
I got the SPL UNIT E back and still find it exceptional sounding. Only complaint is a slight lack of control in the bass. It is here on top of a 2.5k tube amplifier beating it up. I am sure it is not for everyone though. I can understand it's lack of appeal. Also could be that I have it plugged into the PAVANE feeding it via Rednet that helps it sound good.
I noticed that unit sounds best from RCA inputs as well.
The balanced output on Phonitor E sound weird to me... weird sound stage, weird bass. Measurements are worse than the unbalanced output as well. I am listening to only the unbalanced output.
The balanced output sounds fine to me when using balanced inputs but the amp sounds best using RCA inputs and SE output.
"There are two Dip Switches under the E unit as well that serve similar purpose to the first two under the X unit. However here is the other area that you see the E unit is not as souped up out as the X. They both have the same power ratings yet the way they reach that power and position of the volume knob differ quite a bit. I was trying to get the E unit to have as much headroom as the Phonitor X but it couldn’t, even with both knobs activated. Let me take a step back to the X unit and cross my fingers in hopes that I don’t confuse you. All of the knob of the knob of the X is not usable. You will either cause a hard to drive headphone to clip or you blow up your headphones before you get past 12 oclock on the dial this is because the unit is also a preamplifier and the dial serves two purposes. Yet and still, even if you turn the E unit past 2 you won’t get close to as loud as the X unit does before it clips.
It is only boosting the RCA input signal with Dip Switch 2 The soundstage depth decreases If you boost the output signal (Dip Switch 1) and boost the input signal (Dip Switch 2) then you will still not seem to have as much headroom as the X. Also If you boost both the input and output signal of the E unit the following happens The XLR output loosed clarity and becomes less refined ONLY the RCA output becomes louder and and will sound better than the XLR output"
