jonathan c
In tubedom, cleanliness is next to ....
You're gonna love it with that Amperex BB tube, especially the spaciousness and detail that it brings. The BB is one of the best tubes ever made.Just received my Sparkos Gemini this week. I've got the bypass to low and the front gain low to get more tube influence. The -15dB jumpers are in, as I'm driving headphones with the combo. I'm still on the stock tube with Amperex Bugle Boy and Ray Select on the way. I'm using my FIIO K9 Pro ESS as the DAC. Sounds great with either the Sennheiser HD660S2 or the Dan Clark Audio E3. Justin Chancelor's bass tones sound more thick and organic than off the THX AAA output.
Thanks for posting. I need to organize my thoughts better before sharing. The Bugle Boy on low gain was my preferred setup. The 5670 on low gain was not as dynamic. A follow-up listening session will be done tomorrow. I am only changing the gain for now but will try the bias soon.I wanted to cite the Gemini users' manual as it lists 2 ways to change what portion of the overall sound is influenced by the tube as opposed to the solid-state output stage. The sound can be changed through these two settings as well as the type and brand of tube.
First, the user can change the amount of bias current applied to the tube by changing the appropriate jumper inside the unit. Setting the bias to low bias makes the Gemini use more of the tube so its sound will use more of the characteristic sound of the tube. Setting the bias to high will use the tube less and result in more solid-state sound.
Second, the user can change the gain button on the front panel. If the button is pushed in (set for low gain), the Gemini will use the tube more which will result in more tube sound. If the button is pushed out the gain will be high and the tube will be used less, resulting in more solid-state sound.
I found that in most cases with my headphones and on most recordings I preferred the low bias and low gain settings so that the sound was more influenced by the tube, regardless of the tube type/brand used in the unit. There were some recordings, like Thin Lizzy's Renegade for instance, where I liked the greater bass impact of solid-state. As usual, it will be instructive to listen to all of the modes and draw your own conclusions.
I also found that for some efficient headphones (e.g. some Grados), regardless of Jumpers #1 and #2 settings, the front gain button had to be "in" -- to get any useful volume knob rotationI wanted to cite the Gemini users' manual as it lists 2 ways to change what portion of the overall sound is influenced by the tube as opposed to the solid-state output stage. The sound can be changed through these two settings as well as the type and brand of tube.
Update: I had forgotten that I had a rare Brimar 1950s Yellow Tag 12AT7 tube. It is now in use and has added a delightful ever so slightly creamy texture to classical music playback which I enjoy very much.+1 for the NOS Telefunken 801S.
Dan Clark Audio E3 and Sennheiser HD660S2.What headphones are you using? It is nice to have an adapter to try the 5670 tube variants with the Gemini.
