jonathan c
Gemini, 'tubed' with Raytheon JAN 'windmill getter' 5751, is very happy to
with ZMF Caldera Closed!
Nice system. What amp were you using before the Gemini and what are those great looking headphones?I am listening the Gemini with the merason frerot today. A great combination regarding the size on the desk. This is really compact setup with a mature sound. Will try to pair it also with other headphones to see if they are scaling with it. Definitely worth a try.
The Headphones are ZMF Atrium open. I am using mostly the Cayin HA-6a in the other setup.Nice system. What amp were you using before the Gemini and what are those great looking headphones?
Great looking headphones and I expect they sound as good as they look. Cost is more than I can justify but will do a bit of research to see if I should expand my horizons. Thanks.The Headphones are ZMF Atrium open. I am using mostly the Cayin HA-6a in the other setup.
Note: the 6SN7 has a heater (filament) current of 600 mA, while the 6922 has a heater (filament) current of 300 mA. This could be a problem in Gemini.Has anyone tried one of those tube depot 6SN7 to 6922 adapter to expand tube rolling possibilities?
When I owned a Schiit Freya+,Schiit had some solid state 6SN7s LIIST tubes, you could run in place of real tubes.
Good for a backup or if you never want to have a no maintenance pre-amp.
Might be fun to try...if it doesn't damage the Gemini.
Thanks for sharing.Well, the heater circuit can deliver up to 1 A (according to Andrew Sparkos). I did try a 6N6P tube , which draws up to 760mA and it's working splendidly. I use this tube in other rigs and I wondered what if...considering it's a fantastic tube. So I reached Andrew and he gave me the go. The cherry on top, it's not expensive, like many other ridiculously priced tubes. I do advise you guys try 6N6P tube. It's a marvel. Prefer those with red tip or made by Photon.
Happy listening !
A glimpse to Gemini imbued with 6N6P tube
The one difference I noticed between the 2 headphone outputs is, if you have headphones plugged into the 1/4" jack, the pre-amp RCA outputs on the back of the unit will cut out.Very interested in auditioning this amp. I have a bit of an odd question: do the 1/4ā and and XLR headphone outputs work simultaneously, and, if so, are there any downside to running two headphones out of the gemini at once? The wife and I like to listen together, from the same source, whenever possible. Thanks!
Thanks VintageAudio and plcpitt! Purchased! As with all happy marriages, we fight over who controls the volume knob, and she always winsAgree with VintageAudio but would also suggest you contact Andrew Sparks through the sparkoslabs website. Who gets to control the volume?
