SOUNDAWARE M1(PRO) Portable Player with Proprietary FPGA Architecture
Dec 14, 2015 at 1:15 AM Post #496 of 1,094
waiting on @soundaware call
Is it helpful after you swithcing the Fade On?
Or you could re-upgrade the firmware again, maybe will be helpful.
Soundaware Stay updated on Soundaware at their sponsor profile on Head-Fi.
https://www.facebook.com/Soundaware-Audio-CoLtd-140035019979865/ https://www.us.soundaware.net/ Soundaware Official market@soundaware.net
Dec 14, 2015 at 9:45 PM Post #502 of 1,094
I just reflashed. Check if there is a problem still
I had the same problem with fade in once on my basic firmware. I did a pin reset and force recovery and problem was solved
Finally, I find the reason. I have tried many different files, found the crackling sounds when switching between different sampling rate files, like when a 44.1kHz file is finished, skip to next 88.2kHz file, the sound would come out. But only about 1secs.
You please check whether it's the same condition for your heard crackling sound.
Dec 15, 2015 at 12:21 AM Post #503 of 1,094
so....its an inherent issues to every unit?
Dec 15, 2015 at 9:02 PM Post #508 of 1,094
  So you have both? I had the MoJo for a week and Loved the sound with my CIEMs. If this has the same sound like your saying I would much rather have this. Are the vocals smooth like the Mojo and the soundstage was what I liked a lot.
i had the luxury to A-B Esther and Esther > Mojo via Coaxial for a good 1 to 2 hours on 6 seperate occasions. My conclusion stands onlt for the Esther Vitality edition.
