Shane D
Hello. Sorry, but I am yet another noob with the same question you have heard a thousand times: I am looking at buying a DAP and need some advice.
I have about 200 cd's that I want to rip in a lossless format. I assumed that Ipod Classic would be the way to go, due to size requirements.
I then ripped a CD using Windows media player to WMA lossless. That is idiot-proof!
It even got the album art! The best part is the file size which is 319MB, including album art. All done in a little over three minutes (old computer).
So it appears that my total requirements are going to less than 60 gig when I pull out the songs that I will not bother ripping.
Since WMA is SO simple I figured I would explore Zune just to make my life easier. Now it turns out that ZUNE is dropping HD players to concentrate on flash. Flash won't do for me until the flash capacity doubles one more time to 64GB.
Lastly I would like to get a product that works with docks. One relatively HQ to hook up with my stereo at home, so no more loading CD's into the changer. I would also like a speaker dock at work to play my tunes with a decent sound in my office.
NO interest in videos or any social stuff. Just want to play to music with good to great quality, based on what is available (and of course budget, which is probably less than $1,000.00).
If it makes any difference I am located in Canada.
Thanks for your time and any guidance you can offer!
Shane D
Shane D
