Imperatore
- Feb 27, 2014
Thanks Yethal. I actually found the other thread and searched for PS4 and saw this. Is that the best option or is there a non branded cheaper dongle?
Thanks Yethal. I actually found the Orr thread and searched for PS4 and saw this. Is that the best option or is there a non branded cheaper dongle?
Creative bt-w2 bluetooth transmitter works beautifully.
I was wondering, how do you select whether the X7 plays via headphones or speakers? And does it connect to computer via usb? Also how do you switch between inputs like pc, phone, bluetooth etc?
Thanks in advance!
Either plug/unplug the headphones or use the Control Panel. I can be plugged in via usb to pc. All inputs play at the same time. You can adjust the balance via the control panel.
Okay so say my ps4 was connected and so was my phone but I only wanted my phone to play I'd have to boot up the pc to change it? Unlikely but curious how it works haha very tempted by this as there's not many other products out there that fits the bill (NAD D 3020 being the only other option). I liked how it had a manual input selection.
Is it a lot better than using the headphones to the controller 3.5mm jack as well? I'm considering buying a pair of Hyper X Cloud 2's along with this so get my audio set up completed.
There is an Android/iOS version of the panel so it can be controlled via the phone. Frankly, the X7 is a massive overkill for the Cloud headset. Really there is no reason to buy the X7 if You're only going to use it with the HyperX.
when will it have a big sale in 2016
Have you tried connecting earbuds or anything to the controller's 3.5mm jack? The X7 will prove to be a very noticeable improvement with any headphone compared to the controller's output
You don't have to boot your PC to change inputs... You mention you have a phone to connect to the USB Host, so that means you have a smartphone. Download the X7 control panel app for that, and go to the Mixer settings panel. Or, you could simply turn the PS4 off
If your phone is connected to the X7 with Bluetooth and you receive a phone call, the X7 will automatically mute other sounds and let the call take over. That takes care of the only practical situation I can think of where you'd have your phone and PS4 connected and on at the same time but only want to hear phone audio!
Edit: looks like the US store has the X7 for $50 off right now, and the X7 LE for $100 off. Geddit boiiii!
The HyperX Cloud 2 is not a USB headset, right? If it is a normal, analog, 3.5mm single-ended plug connection, then the X7 certainly won't hold it back! I think it's fine to use an entry-fi headphone with a mid-fi component like the X7... I still think you'll hear an improvement vs the controller, and you'll be ready if you get a different headphone later on.
My iPhone cuts out if I get too far away, but... It's an iPhone, and if I'm nearby the Bluetooth connection stays pretty solid. You can reduce the volume for the optical input, or most games also have settings for audio and you can reduce the volume there as well. Sometimes I like reducing game volume because that leaves chat volume the same. So, I can turn up the X7's volume till I can hear my friend's talking well, and then go to the game settings and turn the game down to comfortable levels.
I don't know about the discount being permanent... It could be a school graduate and Father's Day promotion thing.
