This has probably been asked and answered already so apologies.
But how do the N3AP's compare to the A3 in terms of Bass, Mids, Highs and the soundstage? biggest difference i can see in spec is the driver size 9mm vs 16mm? Seen 12mm listed in places for the A3
Thanks
Edit: Wonder how they also compare to the Z5's
They are close yet different. The A3's bass goes lower but are not as quick as the N3. The mid have a bit more sparkles but it also have a 4K spike that can be bothersome to some but can be mellowed out with certain tips. The N3 has warmer vocal coming from the dynamic driver but lacks some details in the mid as it does not have a dedicated midrange driver. The N3 is easier to drive from a phone but if you have a DAP with a bit more power, the A3 is very good. Also depends on what gene of music you listen to.
As to the Z5, Here's some of my posts on the Z5 thread.
Even brand new out of the box compared to my fully broken in A3 (if you believe that stuff). The difference is quite noticeable using the NW-A35 (will have to wait till Monday to try it on the HA-P50 at the office). Bigger sound stage, more controlled and tighter bass that reach lower. Some have said that the high-mids/low-highs are a bit recessed compared to the A3, This turns out to be a good thing as on the A3 they can be a bit sharp at times.
Does seems to take a bit more power to drive, up at 80/120 compared to 70/120 to the A3 (it also maybe that with less of those sharp mids of the A3, I can comfortably run them at a higher volume) . Going to let it play on a loop overnight over the weekend to get some hours in and see but so far, well worth the cost.
I have tried mine on a few DAP/DAC. First up is the Sony NW-A35, It's better than my iPhone but the bass is a bit muddy and the mid are missing some sparkles which is to be expected with only 35mW/ch @ 16 ohm. I then tried them on my Teac HA-P50 (160mW/ch) DAC and they sounds great, the Bass are tight and controlled, the mid is maybe a bit recessed and the high are very detailed, It's one of the most airy and wide soundstage I heard on any IEM and you can listen for hours without fatigue. The vocal are not cold like most BA mid but rather warm. Then I got the MUC-M12SM2 upgrade cable and I got the mid to move a bit forward with more sparkles and improved clarity in general. I highly recommend getting the MUC-M12SM2 as it's much more comfortable to wear over the ear than the stock earhook and almost no microphonics.
Currently driving my Z5 with a PHA-2A via balance output and it cannot be beat.
