hgpardo
How does the Sony A3 compare with the JVC HA-850? They are bass-heavy earphones indeed. Wider soundstage? Better highs?
Are fx850 better regarding mids and bass than Sony A3?
I have them! I like them a lot too. I was wondering how they compared to the IE Senns 800. I was discerning if they are worth the $800? I have the Senns HD 8000 with Cadis cables. They are very nice.
you will need to use the upgrade cable from Sony as the stick A3 connector is shorter than the housing of the H3 mmcxI need some advises with the XBA-H series cable .I just got my H3 back but i need helps .
Can i use A3 cable with the H3 ,the stock cable of the H3 is damaged(both with mic/no mic cable),about to be broken... anytime . Thanks everyone
Hello, sorry for the interruption, i wanna ask you, the XBA A3 is a plastic housing and XBA Z5 is magnesium housing? Hope you'd read it
