329161
- May 5, 2012
It's all relative to how the system portrays the rest of the spectrum. That's the issue with the xm3. The bass is bloated relative to the rest of the spectrum, which makes it sound elevated period.Even Sennheiser Orpheus is light bass headphones.
BTW, how will you describe the bass play in a 5" woofer bookshelf speakers and the one play with 12" woofer floorstanding speakers? Balanced and Bloated bass?
My main gripe with the xm3 isn't the elevated bass. I quite like an elevated bass when it's done well and separated well from the rest of the spectrum. The HDJ8 does this spectacularly well. The xm3's bass has poor resolution and affects the rest of the spectrum.
Btw, you didn't answer my initial question to you. Do all headphones that sound balanced with modern pop have low bass?
