Sony WF-1000XM5
Sep 2, 2023 at 5:30 AM Post #526 of 1,039
I might buy them today. But i see many people complaining on reddit on the wind reduction.
In my experience they're way better at wind reduction than the XM4 with wind reduction on.
Sep 2, 2023 at 5:39 AM Post #528 of 1,039
Sep 2, 2023 at 7:14 AM Post #530 of 1,039
I wish there's an easy way to check the bitrate on iPhone. On a MacBook Air with Bluetooth 5.3, I found this line in the Console app which shows a fixed bitrate of 192Kbps (WF-1000XM5 set to Prioritize Sound Quality):
Code:
ACMP4AACBaseEncoder.cpp:692   (0x1514cae40) @@@@ 'aac ' encoder configuration: srIn = 44100, srOut = 44100, chans = 2, bitRateFormat = 3, bitrate = 192000, quality (complexity) = 32, VBRQ = -1, speechOptimization = 0, packetSizeLimit = 5952 (bits), packetBitSizeMin = 256 (bits), mMaxPacketSize = 1536 (bytes), userBandwidth = 0, delayMode = 0, mCodecDelay = 2112, drcConfiguration = 0, mPrePostFillMask = 0x0
That's quite interesting. I wonder what it says with AirPods?
Sep 2, 2023 at 7:44 AM Post #531 of 1,039
Maybe this?
A2DP LinkQualityReport: Handle = 17 ReTx = 2.9% ( 1 / 34), NAK = 0, NoSync = 1, TxPwr = 4 dBm, RSSI = -49, {50,75,90}th Noise = {-112,-111,-110} for 34 ch, 2EDR pkts = 0, 3EDR pkts = 0, HDR4 pkts = 1, HDR8 pkts = 33, CoexDenial = 0, CoexRequest = 0, rate = 256 kbps Flow off = 0 devicename = <private>
Sep 2, 2023 at 7:44 AM Post #532 of 1,039
I bought the xm5s now. They said that they wherent getting the sennheiser tws3 back in stock :/. And since i had to use my refund for the broken tws3 in the store, i took the xm5s. Tried to get an good price,but the employee was impossible to get an deal with 🤔🤪
Sep 2, 2023 at 9:59 AM Post #533 of 1,039
Ok. That sounds good. The Sennheiser mtw3 was very good at handling wind.
Is the sound good for edm? And how are they for sport/training? 😀
I didn't use them for sport/training, but by shaking my head left and right I didn't feel like they'd come out at all. I used them for about 4 hours without taking them out of the ears and I didn't feel the need to adjust them or to push them back at all.
I like how the bass sounds on these buds, it feels more textured and like it goes lower. I wish they sounded as well as when ANC/ambient sound is off though.
By the way everyone, I may have to give them another listen, but the bass seemed the same when ANC or transparency mode was on, so maybe ANC isn't really causing this - or maybe in transparency mode it still cancels out the lows, so the driver's capacity for lows is limited again (as per my theory). Hopefully I am wrong and they'll improved upon this in a future firmware update.
which ear tips do you use?
These ones, one of the two available tips that came with the XBA-Z5 that I had.
Sep 2, 2023 at 5:16 PM Post #534 of 1,039
So i havent tried the xm5s much yet. But i tested some different songs and also took an walk outside where i had an call to my brother.
The case was slippery. And the earbuds themself was also very slippery. I also struggled to place them correct in the case. They where comfortable though.
I adjusted the equlizer. Found an video on youtube with settings ( arongetsloud or something i think the channel is called ). And the sound was really good. But i might give the edge to Sennheiser mtw3. Their sound is just right up to my taste. But the xm5s was no dissapointment. The microphone/tlf call was good, but not great.
The anc was ok. But sadly, they didnt handle the wind so good. The Sennheisers was much better here.
Going to test them more tomorrow. But for now its a little mixed feeling, but mostly im positive. 😊👍
Sep 3, 2023 at 6:37 AM Post #535 of 1,039
Hello :)
I'm considering to buy them but I've Just few questions.....
1) Does LDAC work even with multipoint enabled?
2) Is it possible to use only one earbud for music and/or calls?
3) How can I answer a call with one earbud? (any gesture?)
4) Ambient sound and ANC works even with only one earbud?
Thank you!
Sep 3, 2023 at 9:01 AM Post #536 of 1,039
Sep 3, 2023 at 9:22 AM Post #537 of 1,039
Hello :)
Thank you!
Yes LDAV works with multipoint on.
Yes you can use one earbud only, just leave the other bud on the case
Sep 3, 2023 at 9:23 AM Post #538 of 1,039
I am currently using the air tips from my IER-Z1R (tge transparent ones), and the sun quality is pretty good
Sep 3, 2023 at 9:40 AM Post #540 of 1,039
Thank you.
What about answer gesture? Is there the possibility to answer a call from the earbud? (right or left).
The gestures is something that I haven't tried, as i use my iphone with screen-reader as i'm blind
