gerelmx1986
PLAYLISTS NOT SHOWING IN THE WALKMAN (OR SSHOWING EMPTY)
Simply when creating a playlist in your music management software check the format is m3u, m3u8, XML (iTunes) the most common and widely supportedif the don't show songs then:
- Go to your walkman directory (or microSD) open the playlist with notePad or other text editor
- in the menu choose EDIT > Replace...
3. in the find what value insert the drive letter for example D:\ drive or E:\ (only put E: or D:) for example in E:\music\Antonio Vivaldi\<Album x>\<track 001>.flac just type E:
4. in the replace with insert two dots .. instead of the drive letter and click replace all so it changes to ..\MUSIC\Antonio Vivaldi\<album x>\<track 001>.flac
