purk
- Sep 26, 2001
Has anyone compared the 707 with the Ibasso DX240 with amp8mkii card?
If you really want to know the difference, i can test it tomorrow as i am going to e-earphone anyway.Has anyone compared the 707 with the Ibasso DX240 with amp8mkii card?
The item has arrived at FromJapan and I've submitted it for shipping! On another note, what SD cards are recommended? I'm looking at either 512GB or 1TB.
I'm wondering if a Sandisk Ultra (U1, claims 150MB/s read speed) will do.
I got one of these in there that I picked up during Amazon Prime Day. SanDisk and Samsung are the ones I would recommend since they are recommnded most by gamers who constantly have their SDs read/write.The item has arrived at FromJapan and I've submitted it for shipping! On another note, what SD cards are recommended? I'm looking at either 512GB or 1TB.
Thanks and looking forward to your impression. Ibasso DX240 with amp8 MKII that I have is quite a bit better sounding than my mod ZX507 so I expect a toss up with the DX240 and ZX707.If you really want to know the difference, i can test it tomorrow as i am going to e-earphone anyway.
But i can already predict that the DX240 most likely has no chance. The main reason to go with the DX240 is the higher output power, but if you really ever need that... thats a question only you can answer
“Better sounding” is subjective. For instance I have the DX320 and Zx707 and I like the Zx707 better.Thanks and looking forward to your impression. Ibasso DX240 with amp8 MKII that I have is quite a bit better sounding than my mod ZX507 so I expect a toss up with the DX240 and ZX707.
That goes without saying regarding each individual preference.“Better sounding” is subjective. For instance I have the DX320 and Zx707 and I like the Zx707 better.
I too got mine a few days ago. Have you experienced any music skips when connected to wireless headphones? I am using with Sony WH-1000X M3. I am connecting first using LDAC and also aptX HD...Occasional but annoying skips....well first off, it's drop dead gorgeous. sony hit a home run on the design. will post listening impressions after a few long sessions with it! I'll compare to my ZX 507 and my Astell Kern.
Hi, if that the case, do you know what is the ZX707 internal card reader speed cap? is it more than 100MB/s Read and 80MB/s Write speed?That speeds will never happen if you have the micro sd card installed on the ZX707 because of the limitations of the sd card reader. So if you are gonna transfer files for the micro sd card, that will be slow.
I bought the Kingston Canvas Go Plus 512 gb which have better specs that Sandisk ultra, and doing some speed test with it installed in the walkman, the speeds were way below of the theoric speeds.
THe way that the micro sd card could reach speeds closed to the theoric ones, is put in a external micro sd reader compatible with the specs of the card, and the speeds for read and write are above 120mb/s. For transfer files the speed are in the same values, but the sd card reader has to be connected to PC.
So if you are ok with the limitiations of the SD reader of the Walkman, and you prefer transfer files to the micro sd card installed there, the Sandisk Ultra would be enough.
But if you wanna faster transfers, in my case, buy a external micro sd reader that allow faster speeds and although the micro sd that you are watching would be faster(I believe), you have other options that are more faster like the Canvas Go Plus, Samsung or Sandisk extreme (those ones have U3 speed class).
Bluetooth wireless is a transmission system, which, like any transmission system, is inherently unstable. It can be affected by many variables, the biggest being bandwidth and signal strength/interferenceI too got mine a few days ago. Have you experienced any music skips when connected to wireless headphones? I am using with Sony WH-1000X M3. I am connecting first using LDAC and also aptX HD...Occasional but annoying skips....
Bottom line is that Wireless is an unstable system, with many things that can affect it. The higher the bandwidth being used, the more sensitive it is. BT cannot be compared to a wired connection.
I remember that the write speed was 17mb/s during the test. The read I dont remember but it was also slow.Hi, if that the case, do you know what is the ZX707 internal card reader speed cap? is it more than 100MB/s Read and 80MB/s Write speed?
Can't believe the internal reader itself was this slow! if the read speed itself under 100MB/s, it seem like there are really got no reason to get high-end microSD card, the entry level itself already at 80mb write and 100mb read speed which cost a lot cheaper compare to other high end sd cardI remember that the write speed was 17mb/s during the test. The read I dont remember but it was also slow.
