I'm not familiar with the HD820, but you're thinking they are very comparable to the HD800S in terms of drivability? Just ordered a Japanese version of the ZX-707 and need some open backed headphones to use with them and want to take advantage of the full potential of the 707. If anyone has had any good luck with other open-backed cans to use with this DAP, please let me know. Sorry, I scrolled through much of this thread, but not the entire thread. How's the start up time and UI speed on the 707? I'm a little worried it's going to take forever to start up, and also be laggy like my ole NW-ZX2.
I think it will be fine, there is difference yes, scroll down and look at the impedance charts for the HD800S vs impedance charts for the HD820; the peak resistance is around 70 to 100 hertz, having the HD800S a peak on 600 ohms and the HD820 around 500 ohms; but both of them average 300 ohms in specs. So about drivability I think you should be fine, you may just need to raise the volume a little higher but not a big deal. Specially with the Japanese version, which is uncapped.
The startup time is like a normal or average phone, give it a minute and it is ready for use. Just don't expect the performance of a flagship phone, here the resources are more focused on power-saving and playback.
UI Speed is average, but somewhere on the thread somebody put a link to another post where it is described which things to change (ie: 0 millisecond delays for animations, disabling system sounds, etc).
From my experience regarding playback (speed):
- Online stuff: fine always (but drains battery faster)
- Using the native player: Instant play, and has a nice screensaver.
- Tidal in offline mode (offline songs on SD card): Extremely slow, I had around 200gb of songs and it took a long while to start playing (between 5 to 10 minutes) and sometimes caused the SD to appear blank (fixed it restarting the device).
- Apple Music (same songs from Tidal): Instant play from offline songs
- USB Audio Player Pro: Instant play from offline songs. Just I had to disable the feature that auto-scans the SD for updated/added/removed songs. I did it because somehow it caused similar behavior with the SD cards as with Tidal, sometimes the SD card would appear empty. (here my guess is that Tidal does massive DRM checks thru all the files, causing the SD controller to go nuts).
- If possible on your environment, disable the feature that requires you to login after the screen goes off, you'll see it is extremely annoying.
- There is another post about hiding the status bar, it requires you to type some adb command, but at the end is good as you'll gain some space on the screen.
