SONY NW-ZX500
Sonywalkmanuser
I feel the best improvement Sony has done this time is the 120 step volume control. It's so finely granular and very linear sounding in every increase or decrease.
elevensheep
- Oct 16, 2014
Is the high gain available for the Hong Kong version?
JPN version.
Question on transferring music files to ZX507 from a Mac, see if anyone here has the answer.
I read the online manual of ZX507 and it says when transferring music files to the ZX507 from a Mac, it needs Android File Transfer App to do that. Can we still do it with dragging the files through Finder (just like the ZX2) after initiate the USB connection?
cfc7
Can it be rooted and remove the volume limit?That's because it has the volume cap on.
kms108
- Jan 27, 2012
like the ZX2, I'm sure the HK version has the volume cap.Is the high gain available for the Hong Kong version?
kms108
- Jan 27, 2012
not that I know of, for the ZX2, there was a temporary fix, but to most people It hasn't worked.Can it be rooted and remove the volume limit?
ASIN
I also find this with the Neutron MP, but the sound seems more analytical and less processed when using it.
I also have CloudPlayer Platinum which I will test later, I am just uploading 1Tb of music first. I also have a 1Tb sdxc card which works well, however I did notice a slowdown in operation with the card full of FLAC. I have not tried streaming (I have a good library organised in a way I can easily navigate), but playing FLAC files over LDAC to Sony headphones I was able to achieve just over 10 hours of use.
The balanced connection can push the Aeon Closed decently, but for my needs it needs some EQ to tame the headphone's highs.
I am curious about the ZX500 & AFC pairing. Can you tell more ?
brokengundam
Well, I prefer a warmer sound generally? I'm almost treble-sensitive (if that's a thing) so in order to feel/hear the bass properly to me I end up having to turn the volume loud enough to where the treble hurts my ears. I bump up the lower frequencies when listening to the AFC to avoid that issue. Kind of avoid the issue anyway, one man's neutral headphone is another's bright headphone. I can't say I listen to the AFC much these days due to having other over ears that passively isolate better (DT770m) but when I do pull them on they sound great.
Using the high gain setting with volume at 61 or standard gain at 80 with +6 to +9.5 boost with the Sony EQ to various bass frequencies is plenty loud and enjoyable for me on the ZX507 through the balanced connection. I haven't tried the AFC via the 3.5mm jack but I doubt it'd be worth my effort in finding my XLR to 3.5mm adapter...
edit: for reference, my CFA Equinox IEMs are comfortably loud in a quiet environment at 32 volume with standard gain, and get turned up to maybe mid 40s when on the subway.
Sonywalkmanuser
Neutron MP has dithering which I think is why it sounds more natural. However I still think the stock walkman app trumps neutron. neutron is lacking in crispiness.
Now after my ZX507 has more burn in time(sibilance is getting lesser). I am prefering the Stock Walkman Music app over USB Audio Player Pro HiRes output. Reason is there's more musical details in the sony app. So far I have tried the following app on ZX507:
Fiio Player
Hiby Player
Onkyo Player
Neturon Player
I still think Sony's Stock app sounds best because of it's excellent detail retrieval.
Fiio Player
Hiby Player
Onkyo Player
Neturon Player
Thanks. My worry is if the ZX507's balanced output can drive the AFC or not, so it can succesfully drive?
brokengundam
Yes, the balanced output will drive the Aeon Flow Closed. Note that I'm using the JPN version, so it doesn't have the volume cap like the EU versions.Thanks. My worry is if the ZX507's balanced output can drive the AFC or not, so it can succesfully drive?
I have the opposite question: is it possible to set an arbitrary volume limit like you can on the iPhone?
psikey
- Jul 15, 2008
Fiio Player
Hiby Player
Onkyo Player
Neturon Player
And you get more battery life using it !
Total: 23 (members: 0, guests: 23)
