SONY NW-ZX500
Aug 24, 2020 at 8:04 PM Post #4,471 of 8,654
Optimize your ZX507 for Better Sound Quality in Walkman Music App sdcard playback only mode.(not streaming at all).
This tweak will help improve the sound quality of your ZX507 for offline playback by disabling all unnecessary apps and services.
To reset this tweak, just do a factory reset.
Requirements
Firmware is updated to 2.00.10(or latest)
Backup any important data stored on walkman internal storage
Recommend to format your microsd card using the walkman android OS itself and not via Windows/Mac/Pre-formatted
Settings > System > Advanced > Reset Options > Erase all data (factory reset)
Once this is done, just go through the initial setup.
Do not enter WIFI connection details and do not log in to your google account.
Settings > Wifi > Airplane Mode > On
Settings > Wifi(press on icon) > Wifi Preferences > Switch off everything listed here
Settings > Connected devices > Connection preferences > NFC > off
Settings > Bluetooth(press on icon) > Wireless Playback Quality > LDAC Sound Quality Pref. (this will set LDAC connnection bitrate at highest 990Kbps)
Settings > Apps and notifications > See all 28 apps > Press on the three vertical dots on the top right corner of screen > Show system >
From here you are going to press on each app and disable them individually, these are the apps to disable:
Android Accessibility Suite
Android Setup (clock icon)
Android Setup (gear icon)
Basic Daydreams
Block Numbers Storage
Bookmark Provider
Calculator
Calendar
Calendar Storage
Chrome
Clock
com.android.cts.cts.shim
com.android.cts.priv.ctsshim
com.android.providers.parnterbookmarks
com.android.soundrecorder
com.google.android.gms.policy_sidecar_aps
Companion Device Manger
ConfigUpdater
Contacts
Contacts Storage
Default Print Service
Digital Wellbeing
Download Maanger
Downloads
Drive
Example Wallpapers
Gmail
Google
Google Backup Transport
Google Contacts Sync
Google Japanese Input
Google One Time Init
Google Partner Setup
Google Pinyin Input
Google Play Music
Google Play Services
Google Play Store
Google Services Framework
Google Text-to-speech
Headphones (don't disable this if you are using Sony bluetooth headsets)
Help Guide
HTML Viewer
Intent Filter Verification Service
Maps
Market Feedback Agent
Media Storage
mora (for japanese firmware only)
mora qualitas (japanese firmware only)
MTP Host
MusicFX
Photos
Print Service Recommendation Service
Storage Manager
User Dictionary
Youtube
Next we are going to disable battery optimization:
Settings > Apps & notifications > Advanced > Special app access > Battery Optimization > Press on Not Optimized > All apps >
From here we are going to select each app and select Don't optimize.
Do this for all apps except those apps that have Battery optimization not available
Next we are going to enabled 2D GPU acceleration
Settings > System > About Device > Build Number (Press 10 times on this to get developer status)
Settings > System > Advanced > Developer options > Force GPU Render > On
Windows animation scale > Off
Transition animation scale > Off
Animator duration scale > Off
Settings > Accessibility > Remove Animations > On
Settings > Sound >
Media Volume > slide to most left
Alarm Volume > slide to most left
Notification Volume > slide to most left
Settings > Sound > Advanced
Screen locking sound > Off
Charging sound > Off
Touch Sounds > Off
Once you have done the above. You have to make a choice between two sound modes. Yes, this setting affects the sound of the Walkman music app.
Settings > Sound > High-Res streaming >
ON: More 3D-like soundstage, more distant vocals
OFF: Less 3D soundstage, Vocal imaging is better
If you want best sound quality when using DSEE HX, It is recommended to turn off battery saver as it affects DSEE HX AI processing. If you are using Direct Source Mode, it is ok to use battery saver mode.
Aug 25, 2020 at 1:53 AM Post #4,473 of 8,654
Are there any cons that I have to know before buying this dap? I am looking for something to stream and this seems like a good choice Thanks!
Only problem I would see is battery life when you stream is even less that Sony claims.
Aug 25, 2020 at 2:20 AM Post #4,474 of 8,654
just be sure u don't buy EU model. u really want that high gain. otherwise ur headphone choice will be very limited.
this problem can be solved by powerbank.
my old xioami 5000mAh (2.1A, 5V) charged zx507 more than 50% in less than an hour. no excess heating while playing music on 4.4 balanced output same time on max volume (i was testing hd820...)
Requirements
From here you going to press on each app and disable them individually, these are the apps to disable:
Adoroid Setup (gear icon)
Basic Daydreams
Bookmark Provider
Calculator
Calendar
Calendar Storage
Chrome
Clock
ConfigUpdater
Contacts
Contacts Storage
Digital Wellbeing
Download Maanger
Downloads
Drive
Example Wallpapers
Gmail
Google
Google Pinyin Input
Google Play Music
Google Play Store
Help Guide
HTML Viewer
Maps
Media Storage
MTP Host
MusicFX
Photos
Storage Manager
User Dictionary
Youtube
Settings > Sound >
Touch Sounds > Off
how do all these system tweaks effect the performance?
maybe I am wrong, but it seems Linkin Park 1st album sounds significantly less dirty with hires streaming on vs off.
can u explain me a complex influence of this switch?
by the way What is "the safe mode"?
and how does it effect the sound and performance?
Aug 25, 2020 at 7:58 AM Post #4,475 of 8,654
different type of sound processing between High-res streaming ON vs OFF. Pick the one which sounds good to your ears
Safe mode seems to switch off sound processing. Its like a Digital filter has been removed. It’s very sharp sounding.
Aug 25, 2020 at 8:04 AM Post #4,476 of 8,654
Safe mode is a function of the Android Operating system that disables any downloaded or third party applications from starting when the machine is started up.
Aug 25, 2020 at 11:38 AM Post #4,477 of 8,654
And don't buy an EU volume capped version. Its not just loosing High Gain, the whole volume range is dropped.
A volume of 70/120 on my Japanese import was 100/120 on the Amazon UK one I tried first. Add in the High Gain option and volume with same earphones is at around 50/120 !
Its the lowest capped volume of recent UK ones I've had such as ZX2 and ZX300 (before I removed the cap).
Aug 26, 2020 at 3:35 AM Post #4,478 of 8,654
Out of curiosity, I currently use Tidal to stream HD tracks however I'm wondering if Amazon music HD would be a better choice as far as their suggestion engine might point me to more music I might like? Does anyone know if this is true or not, it just seems like it might. Also does Amazon let you download music for offline listening?
Aug 26, 2020 at 3:48 AM Post #4,479 of 8,654
In my opinion, for offline Walkman music app playback, ZX507 sounds much better with Hi-Res Streaming Off.
1. Transients feel more cleaner, sharper and faster
2. DSEE HX seems to have more depth
3. Vocals feels more holographic, better imaged
Do give it a try. You might like it as compared to Hi-Res Streaming On.
Aug 26, 2020 at 3:58 AM Post #4,480 of 8,654
Amazon has a better suggestion engine for me and my music tastes are pretty eclectic.
I can also download music For off line but I don’t have the android version but I’d be amazed if it didn’t have it too.
Aug 26, 2020 at 8:37 AM Post #4,481 of 8,654
If hi-res streaming is off, will youtube music (and other non nativeapps) be upsampled to 192/32 when I turn on DSEE HX upsampling?
Aug 26, 2020 at 11:28 AM Post #4,482 of 8,654
It should be like this:
YouTube music > android audio@16 bit 48Khz > Dsee HX@32bit 192Khz
Aug 26, 2020 at 11:48 AM Post #4,483 of 8,654
Was thinking of buying an SR25 from Astell and Kern and decided on the zx507 instead. Can I confirm that the Sony Asia Pacific version is not volume capped?
Aug 26, 2020 at 2:22 PM Post #4,484 of 8,654
No Caps in Asia.Japan or China.I got a Chinese model.No Cap.Excellent DAP.
You chose wisely. I've read that ZX500 series bests even the $1499 KANN CUBE
Aug 26, 2020 at 2:44 PM Post #4,485 of 8,654
@sander93
have you tried out the offline only tweak that I posted earlier?
I think it really helps to improve the ZX507 sound quality.
  • Back
