mwhals
- Jul 26, 2015
Anyone listen to the DX507 with an Empire Ears Phantom? Is it too warm of a combination?
Is it possible a line-out could be added with a firmware update, or only on a hardware level?
It's a great dap other than that.
Alternating between: Hi Res streaming off, Direct off and DSEE HX On, all others off.
Hi Res Streaming off, Direct Sound On. Which doesn't sound as 'dry', like the former. maybe it depends on the recording?
@T.R.A.N.C.E.
I notice that there is a difference in sound when you play offline music files on the walkman music app with:
A. Hi Res Streaming ON
B. HI Res Streaming OFF
On seems to have more 3D processing with vocals more distant
OFF seems to place vocals more forward, imaging seems to be better focused.
If you combine OFF mode with safe mode along with direct source ON, it is the least processed sounding I have heard on the ZX507, extremely fast and raw sounding transients. High gain can sound overwhelming, recommend to use low gain. Also this settings seems to sound really great on DSD files, seems to give DSD music more dynamics and even more clarity.
Yes it really depends on recording.
Also you should try out safe mode:
With screen turned on
Hold down power button until you see the restart popup
Press restart
Hold the volume down button when it is restarting
You should see a safe mode word at the left bottom of the screen once its up and running.
This mode sounds totally different. Use low gain if you find it overwhelming strong.
In this mode you can also experiment with Dsee and other dsp.
120/120 high gain works fine as line out.
can't understand how full volume from the amp will work as a line out, I will try it.
with high-res streaming off, that does not affect Tidal 16/44.1 tracks?
Is there a way to play through folders/albums? the manual is unclear about that.
Thank you!
FWIW, I've used the ZX-507 3.5mm output as a lineout, mini-to-mini connected to a quality Vorzuge amp (for sale in my sig). Max volume, high gain. Sounds terrific, zero distortion, zero graininess.can't understand how full volume from the amp will work as a line out, I will try it.
Thank you!
Unlike a number of other DAPs, completely digital volume control, so using higher volume numbers will not be introducing additional noise into the amp. You're not bypassing the inbuilt amp, but with direct source on you're getting the as intended Sony sound. Audioquest dragonfly works the same way. No line out, but with digital volume control, was expected to be run at full volume into an ampcan't understand how full volume from the amp will work as a line out, I will try it.
Thank you!
