waiting for benks case to be shipped..
Looks perfect that! Ordering if I can find UK delivery.
On AliExpress for about £15 inc. P&PLooks perfect that! Ordering if I can find UK delivery.
Indeed. 1500mAh is to blame here. I love my zx507 though. I use it more than my 1Z because of small it is. It drives my HD800 very well.
Wow, this case looks pretty! Almost worth getting the ZX-500 for this case alone!
Anyone tried recording with a USB-C microphone?
@purk, can you share the specs and source for the wires you used? Gauge, solid/stranded, pure silver with gold alloy? By any chance from Parts Connexion?
From your pictures, it looks like access is simple, and not too complex or tricky to get at the wires/PCB board? And what would you recommend for the wire for the battery?
reinstall Spotify and clear cache
https://community.spotify.com/t5/Android/Android-App-crashes-constantly/td-p/4778291
Hey all,
Thanks for reaching out.
Let's do a clean reinstall first. Before that, you'd have to disconnect all devices from your account here.
Then follow these steps:
1. Go to Settings on your phone.
2. Select "Apps".
3. Tap "Spotify" in the app list.
4. Tap on "Storage> Clear Data" for a clean reinstallation.
5. Tap Uninstall.
6. Open Google Play and install the Spotify Music app.
There is something else you could do if that does not help. Go to:
1. Mobile Settings> Apps> Spotify> Permissions. Allow everything you see there.
2. Mobile settings> Apps> Spotify> Battery> Optimize battery usage> select top All (not optimized for apps)> Spotify> disable.
3. Last step - restart the phone. Then everything should be fine
Let us know how it goes!
I know its sacrilege to even consider it but has anyone tried Spotify and found solution to it closing the App mid play? I read some on the A105 having the issue and even does it on my phone for a while now.
Think it tends to happen when screen is off but I think I've disabled all possible battery saving options that could be doing it.
