djricekcn
- Dec 2, 2014
Does anyone how to hard reset this unit.
Hold down the screen on/off button for along time
soft reset should be taping that button and selecting reboot. holding it down forces a shutdown, thus a hard reset.
Why not just return it, and get the US version.Thanks, the information on the unit is misleading, at first I just kept using the hardware key, I wish it was simple just like the Samsung volume+power+home.
I understand what you say, can you use the volume without first using the hardware button, my Samsung on android 4.2 works without the hardware button.
You don't have to use the hardware button first to bring up the volume slider. Use one of those volume slider widgets from google play and put it on your home screen.
What version is mine?
Hi,
I'm trying to get my ZX2 to work with my Hugo, but i'm having issues with it.
I'm using Onkyo HF unlocked. Whatever i play using the Onkyo the light on the Hugo is Red (44.1) it does not matter whether the file is a DSD or normal redbook. It does not change colour.
On the Onkyo player the settings is set to
DSD Output format: DoP
Onkyo USB HF Driver is valid (ticked)
Output Audio Route: Device.
Am I missing something?
Haven't tried the DoP setting, I use PCM and it works on my iPhone and ZX1. You might try that setting first to see.
Hi,
I can hear the sound in PCM or DoP. It just when I'm playing it either in Dop or PCM the light on the Hugo is at red.
Never had no issues when I was using my iphone with the Hugo. The lights worked as it should.
