- Oct 14, 2013
Used in mint condition th900 is 800-850 not too bad eh ?
Note that if you take a digital signal out of the ZX-2's WM port (into a Mojo for example) the battery life plummets like crazy. That was one main reason I sold my ZX-2
Has anyone had experience with the zx2 and the Oppo Ha 1? Are they comparable in sq? Is the Zx2 a worthwhile upgrade to the Zx1?
Any rumors about a NW-ZX3 ?
NW-ZX2 was launched 1 year ago, which is an eternity in SONY's marketing world
Any rumors about a NW-ZX[COLOR=FF0000]3[/COLOR] ?
And your point is? This only matters (if it matters at all) to people who own TOTL headphones or IEM's. A £235 cable won't change my £175 SE425's.
If i personally were to get a Mojo, it would be to use at home, where I would also just plug the Sony into an outlet. So shorter battery life would not be an issue.
I also have saved a Lot of money with the Streaming. I have downloaded thousands of songs, playlist and albums from my Tidal service.
Ah, yes sirfostex th900 isn't a low-end headphones by any meaning. My point is that it is real as measured, and the audio improvements is indeniable only measured by the headphones and cables....TRRS out by zx2 is also very real on to improved sonic quality
Unless you modify the cable into the Sony WM port though, you can't charge it and take out a digital signal into the Mojo at the same time.
