purk
- Sep 26, 2001
Connect it to a computer may solve your issue.
Hi just confirmed that Region change afected sound on my zx100 so If anyone still owns one of this you may confirm if im wrong or not best one its J region! and I also like MX3 cheers also J enable couple of things a rec buton and a new HEadphone aunder clear phase that sound diferent when enabled.
MX3 ----- Detailed and rumbly low bass with loads of detail Stock FW of my 1A Focus on highs and mid-highs
J -------- Thick very warm and some mid-bass present elegant… is thick, rich & emotive
CN ------ Similar to MX3 but with better resolution slightly more piercing
CA ------ V sound
CEV ---- Elevated highs and more power shallow bass? slightly narrow and difuse highs
E -------- too much V to the point of being harsh in the highs
E2 ------ Cavernous and Loud Forward Sounding
KR------ Very Loud and refined! Slight focus on the mids Has some some midbass... it since as its turns 3.00 closer to 2.00! (not stellar definition to my ears but very good volume) maybe a little recesesed bass.. compared to MX3
maybe 256gb, i have 128gb sd at the moment, i think as long you physically reduce the photo embedded size to very small ideally 120 x120, but less than 640 x 480, if have massive ones 1200 x 1200 it slows the ui, probably no limit in tracksWhat's the biggest micro SD card that works with the nw-zx100?
I have a 200GB card installed but can anyone confirm if a 512GB card works please? (Is there a limit on the number of tracks this Walkman can read?)
it is a good dapI am regretting having killed my zx100, I had within 1.5 years two retinal detachments, and this little DAP was the last sony made without touchscreen for ui navigation
