proedros
edit , question answered by (stupid) me
Is it safe to keep the Sony NW-WM1A plugged into a 5v=2A charger, while playing continually?
If by continually you mean "forever" - probably not. However, playing & charging at the same time I think are fine. Having said this, I imagine you are burning in your new cable - and will seek to leave it playing continually for several hundred hours?
Yes, I am burning in balanced cables and balanced amp.
I wouldn't, but I know others around here have done so. I would imagine at the very least you would want to run the 1A on battery for a few hours every now and again. The chemistry of the battery these things contain is complex and shrouded in mystery and folklore to be quite honest. I do know that if you continually leave a laptop plugged into the mains, you will have a detrimental impact on the battery - so I imagine these devices are similar.....
And folklore......HAHHAAHA
Skipping rope attachment !! Whatever next
is useless to try and mimic A&K line-out design.
It
1/ Ground terminals are never connected on the 4.4 TRRRS to the board
2/ TRRS on the 3.5mm will not work by any meaning, and when both is plugged in, Balanced will be the priority. So the 3.5mm will be just a sitting duck...wasted away.
3/ the Sleeve on the 4.4mm can accommodate a full sizes body cables shielding just fine, and again....it is never connected to the board.
4/ last and not least, any noises being absorbed and deflected should never be routed toward the source....AKA the player itself. Therefore, A&K design was nothing more than just additional pins and plugs for stability....and that is because 2.5mm is flimsy as heck.
I am baffled to see what Kimber is trying to do here
