gerelmx1986
I think the XBA-Z5 need more current because the cross-over (triple driver IEM) and Z7 are just fine on normal gain because just one driver
Do you have the provision to run Ether flows balanced on WM1A? Balanced output has more power. Anyways, for now it only appears that a 4.4 to 3.5 or 3.5. to 3.5 can help you.
And don't get just any cheap adapters. I heard they can short your player.
Is anybody using a dock with wm1a instead of a macbook pro as source?
i am nearly hitting 700h in SE and i am dying to try out balanced
Have you compared wm1z as source vs macbook pro?
Do you still like the sound?
Is it improving over time?
Mine has stabilized arround 550 hours, I love the sound but like everyone esle i wan t also to try the 4.4mm
Have not got your 4.4mm yet?
None the less about 100 out of my 1500 albums fail to show album art on the 1Z despite showing on ZX2 and all other devices I have used. This also on 1.10
