zardos
- Nov 6, 2008
Negative. I know that will produce higher sound levels, but I guess my inquiry is more trying to address whether it is normal that should even be a thing that I should need to engage high gain mode with the very sensitive, easy-to-drive Andromeda? And if so, how does that translate into usage/enjoyment of the 1A with something like the HD800S, or similarly harder-to-drive headphone?
Don't know about the Andromeda, but HD800S, high gain, volume @120, random music: Crazy loud. Don't do that for a longer time period! Btw. there is a dsp setting to even up the loudness levels for differently mastered tracks. Works fine. I don't need it yet.
The loudness difference between IE800 and HD800S is surprisingly small. It is bigger between JH13Pro and HD800S, but also not as much as I would have expected. 1Z and 1A balanced have no problem to drive a HD800S adequately. HD800 might be a little harder to drive because of the brighter sound sig.
