erictioh
- Nov 20, 2013
You mean that the new player sounds bad single ended and worse balanced ?
My understanding his question is having 4.4 balanced to 3.5mm adaptor single ended, and then use a singled ended earphone right ? If you do that, it will sound worse than directly plug into 3.5mm single ended. wm1a 3.5mm single ended port is awesome, 4.4 balance port alone is really really awesome, but 4.4 convert down into single ended is worse. I don't know why, maybe it short circuit hehe.
