TenderTendon
- Sep 15, 2016
WHAT?! Power measurements give you a good notion as to the power of a device? Such blasphemy! I won't stand for it!
I agree. Complete hogwash!
It would be great if you could made the same measurement for DX200 balanced output
Wow ... Cowon S more powerful ?
Please make some comparison between thise two
Man this dap is great. It's burning 21 hours nonstop but it isn't warm at all. It doesn't like my all opus1, dpx1, ak70, qp1r, they got really warm easily. And battery is awsome. Love it
Ok i will check it later
I saw they just have 2.5mm, 3.5mm
i thought wm1a does not have tidal
It does not have Tidal. I think he meant it is the only thing lacking out of those ticked boxes
What has this world come to when we discard measured data in favor of opinions? Well, here's some more data to ignore...
I just measured the output of the 1A and 1Z. They both measure exactly the same, BTW. All measurements are on the balanced jack using high gain with a 1Khz test tone. I don't have a QP1R here to test, so all I have to compare with is the manufacturers published specs.
Into 300 ohm load = 2.06 volts (14mW) A slight edge on the QP1R at 12mW (approximately 17% higher).
Into 32 ohm load = 2.02 volts (128mW) 3 times the QP1R's claimed output of 40mW.
Into 16 ohm load = 2.0 volts (250mw) The only posted dated for the QP1R into a 16 ohm load is 16.3mw (Wow!).
This data shows that the Sony and Questyle have a somewhat equal maximum voltage output, but the Sony is capable of delivering MUCH more current.
Well how come my vegas is less bass than usual when i pair it with 1A ? i don't know that did i do something wrong in settings or not lolz.
Comparison for someone who is interested. If you are so sure on measurement numbers, don't bother.
QP1R beats 1Z on balance mode by a small margin in term of driving power.
Credits: @rudi0504
Looks like it's just a small margin.
It's not like heaven and hell of a difference.
So there is nothing to fight about. Chill guys.
