- Feb 19, 2013
My guess would be they might disable this workaround in a future firmware (assuming they see this as voiding the warranty, etc). In that scenario, all current units would be able to still disable the volume limit, but new units with a more recent firmware may no longer able to. I also think once enabled, it's not likely to revert with future updates, seems like they're just going off internal region settings when installing firmware.
Still, I'm glad this worked for you, and without much incident it seemsThe only question remaining is the effect on warranty, though I'm sure it's still worthwhile for many to do this
Well the great thing is it's fully reversable.
I'm not sure Sony will worry about preventing it either. They only set the limitation to abide by EU laws, which they have done. It's not their fault if someone manages to bypass it.
