gerelmx1986
15?! WowWhat volume do you guys listen at?
In quiet office I listen at 15/120 while when outside I listen at 60/120.
15?! Wow
I like this combo but till I try balance can't say for certain,How is the T8iE MKII with the wm1, i'm considering the [COLOR=0066CC]Xelento!, the new version.[/COLOR]
Just got my m12sb1. Both channels work nicely!
It should, because it is stocking from Sony
So begins the burning in process all over again...
You're right, its a modified Sony Kimber cable. I had a shop here in HK install a 2.5mm female into the cable.
God damn....expensive cables to be splicing and modifying off LOL..... I would rather wait for the Jacks and the socket availability . But I totally admired your result
I use mine with FLAC, bare minimum 16/44.1Yeah, I thought so. I use Z1R in balanced and high gain....I can not use it below 70, and gotta be comfortably only around 70-80. But volume that you guys listen too is not important, but more importantly.....How many bought it to use with MP3
After 200 hours on single ended i now have balanced cables.
Do i need to burn in another 200 hours on the balanced side for the sound to be decent?
Must say the added thickness on the balanced side is fairly enjoyable
Yep another 200 hours, at least.
