gerelmx1986
Well I was considering 1TBFYI. Nowadays, price difference between Extreme and Extreme Pro is small, around $10 for 512GB or 256GB.
I only use Extreme Pro 256GB as it can store around 200+ Album (1/3 red book FLAC, 1/3 hi-res FLAC, 1/3 DSD) which is more than enough for 2 months listening.Well I was considering 1TB
is quick format with the sd formatter good enough?For those who are willing to experiment with or planning to upgrade to the sandisk extreme pro,
I am recommending to perform another two step when you receive your new card to further improve sound quality:
1) Format the card with this tool:
https://www.sdcard.org/downloads/formatter/
2) Format the card once more with your walkman OS
Now you can start to transfer music files into card.
In my subjective experience by formating with the tool helps to improve the microsd card's background noise floor.
WHy wont you answer PM?Well I was considering 1TB
Depending on the color of the player, some icons can also have different colors. I managed to find out how to change that, it should be a nice little customization option. There will be a little tool to change that.
WM1A can only be black and have the white color from the factory, as well as the WM1Z, but the option works for them too.
Great great first person impressions shared!This is a masterpiece.
Not something you “need” to have but very cool aesthetics to have and use customizable colors for our players!Depending on the color of the player, some icons can also have different colors. I managed to find out how to change that, it should be a nice little customization option. There will be a little tool to change that.
If you can change the EQ colour it will be awesome!!!Depending on the color of the player, some icons can also have different colors. I managed to find out how to change that, it should be a nice little customization option. There will be a little tool to change that.
While this list is greatly appreciated, one thing not considered, is that testing on that different DAP, (running Android) would certainly have a different susceptibility to the memory card.After re-evaluating the microsd cards on my ZX2 walkman(initially the cards were evaluated on my zx507), and with more listening, I have to revise my rating.
Subjective rating:
Sandisk Extreme Pro 256GB: S
Toshiba Exceria M303 32GB: A+
Sandisk High Endurance 64GB: A
ZX507 Internal Storage with microsd inserted: B+
Adata Premier Pro 128GB: B
Samsung Evo 32GB: C
Lexar 633X 512GB: D
This is an interesting comment. I am thinking weather the increase in battery and also the power cap upgrade, could offset the issue noticed by "one" user.The flicker most likely has to do with lack of power or a configuration issue
Well, let's hope they do not go full Android...The only piece of info I received and from the source I consider reliable enough for me to share with you is about the 1A and/or 1Z successor in early 2021. Can't speculate on anything else, sorry.
Those may have just been de-throned:I actually don’t use the IER-Z1R IEMs everyday yet they are actually the most technical and honest IEM I own
NO... It's not just a music player.....In the end, it’s just a music player......
......In the end it’s just a hobby....
....If it don’t work then let others’ say so instead of being combative is all I’m saying...
This is similar to what I have observed in general, of the differences "in the past" of the 1a & 1z..... am I correct that the volume sounds a little quieter and gentler, just smoothes out the highs, mids, and lows to make it more cohesive and easier to listen to the ears than the stock 1Z?
Yes, they said in past they used other things in their mod, but they not disclose it.Our thread is about sharing so we can all learn from each other but just taking and profiting by Music-Sanctuary with ZERO contribution/sharing is not cool !
We don't know how the unit's internal sheilding, PSU on that board, and interface is.
Yet, I do think that the driver preformamce inside each card is obviously different.
You have determined that..
Yet wether these differences would be similarly noticeable on the 1a, that is the question.
heeeiill NO!
The closer it is to the 1a interface, the better for "future upgrades" here...
It's an end game choice, at this stage.
NO....it's not just a hobby, it's more of a journey, and also of much money... thousands spent in the search and conquest of music bliss..
The Last NO, is because you have not been in thread early enough to see the whole picture. The issue of reiterating the same install problem for the third time(4th?), which in a nutshell is not actually installing.
TBH, I find suspect when a new mod is pushed at peculiarly the same time a big upgrade is mentioned going to be dropped by Mrwalkman.
It should have been mentioned to be an xml tunning that also require you to go back to the "now" inferior stock firmware just to put it on.
Why not instead, use latest mod firmware?
It would be great if any future XML tunnings would be with the latest moded firmware, instead of regressing away from all the major progress made.
Tunnings are appreciated and nice to have, but not at the expense of loosing the current moded firmware upgrades.
Currently, we already have about 4 options in each firmware.
The 1z sound is a perception of increased soundstage, which also makes it less forward and more realistic in presentation.
The question is if your IEM can produce the soundstage, as many have "in the head" syndrome with center image (to a certain degree).
I have their mod.
It is not a copyright.
I will go over everything done.
Lucky for them I have been totally busy whole summer and delayed my mod plans.
I did compare mine to stock, and do like the 3% sound difference, but I am convinced it was a minimal mod of stock wire upgrade.![]()
Although the reviewer aludes to tuning of the drivers working well together, and the "bone conduction" adding to the mids, I am starting to think the actual unique improvement may lie in the electrostatic type driver it is using...That's a very high recommendation for UM Mest; convince me to get it, hahaha
But seriously, what's so good about the UM Mest? I mean to place it above IER-Z1R sounds incredible
