It will arrive tomorrow. There should definitely be an improvement, I'm curious as well
I’d love to be able to mod my A45. I use that when I’m travelling sometimes instead of my WM1A
Totally true about getting longevity by not needing Android updates. Not in fact having player dependent upon past or future updates for functionality is a breath of fresh air. Also strangely the players became able for a faster UI experience with later firmware.
Android devices especially older versions has a tendency to suffer from slowdowns over time, more so if you install many apps. One of the reasons is because of file fragmentation. Manual clearing of cache can help.
https://www.tuxera.com/blog/why-is-my-android-phone-slowing-down/
https://www.usenix.org/system/files/conference/hotstorage16/hotstorage16_ji.pdf
On the ZX2, you can clear cache by going to:
Settings > Storage > Cached Data (press) > OK
This should resolve the slowdown of the ZX2 in most cases.
A factory reset for ZX2 once in a while should solve all slowdown problems.
Even for modern android smartphones and modern Sony Android Walkman A105 and ZX507, I would recommend downloading Google files from the App store to perform the removing of junk files once in a while. It will restore your android device responsiveness to near factory reset levels.
Both ports are able to be wiggling around if your force it to. The mechanism is hook and lock in mechanism. It was implemented for reliability purposes.Cheers!
A quick Q - 3.5mm out - inner black plastic circle - is it normal that it has just a little
looseness, plays a tad?
This one:
Yep, and especially being able to run the newer version of the WM1's firmware, which runs better than the laggier firmware of the A45. Both players use the same SoC (CPU).
No FM radio though.
So it's pretty useless in my case, isn't it?
Yes, maybe there is a hidden line out? Haha.
It would be one of those old-school adapters like above that you would plug a 3.5mm into?
Line out used to be possible with Zx2. On the WM1A/Z, the engineers eliminated it as it could act like an antenna that absorb noises toward the S-Master. So even if you were to use the Line out WM plug, you won’t be able to get line out. But it could be that the engineers said so because it was not enabled ? There is a dongle for that to use on ZX2, which I don’t remember the name, and it is also WM port dongle
I know that WM1A used the same SOC as DMP and also have dsd remastering features, but it can not be enabled as S-Master is MultiBit where as DSD is 1 bit
best way to know -at least for me- is to try, as long as I am going to play with ins and out with no USB voltage or power, the chances of breaking my beloved WM1A should stay low.
i will post my findings once I receive the plugs and try these methods. Not soon though
? How can it be? I thought that C-PLM being the main thing in the S-Masteras S-Master is MultiBit
You won't break your WM1a because there are no physical connections inside of the WM1a to the line out pins of the WM Port. There is also no audio in support either although the WM Port has a spec for it.
