Mystic Traveller
A quick Q re charging WM1: a 2A charger - is it OK to use, not too high current (amperage)?
please stop with this chi-fi madness , it's boring and not really 1a/z-related
peace
Indeed - no reported deaths or lynchings yet from audiophile disputes.
Lossless files can be categorized into three types:
No data compression (PCM WAVE or FLAC lvl 0 )
Lightly compressed
Highly compressed
I do think that highly compressed(non-lossy) can sound subtly *worse due to more processing work and memory I/O required to unpack the compressed data. This processing and l/O will generate more electrical noise and cause more power drain on the audio player, which ultimately has some impact on sound quality.
*Again it will all depends on how golden/trained your ears are and how good your equipment and how quiet your environment is, for you to be able to notice the above effect.
Good! Thanks, mate!So having a 2A charger for a 1A device is actually good.
Not many music recordings out there being sold as PCM format and converting something else to PCM is not a viable optionGoing to use a water hose analogy:
I think the reason why PCM wave might sound better is because playing back constant streaming data with very low constant processor usage has more consistent and deterministic power draw & system jitter. Think of a water hose that provides consistent water flow pressure, noise generated by from the water flowing out is consistent and not as noticable to the ears
While if you playback something with variability in processor power usage with segment by segment data decoding inside the CPU small L1 &L2 cache, it causes random spikes in power draw & system jitter. Think of it as water hose that has inconsistent/jumpy water flow pressure, thus the noise generated from the water flowing out is spiking/more splashy and noticable to the ears.
That's all noise due to the implementation of the hardware though, not because of the file format itself.
Ultimately the file format has to be played on a system. Maybe with the current portable hardware technology/software design we have, isn't capable of playing back compressed files without degradation. A powerful x86 desktop processor system might be able to play compressed files without degradation to sound quality. It's all speculation on my part.
$233.99 https://www.amazon.com/gp/product/B07P9W5HJV/Not many music recordings out there being sold as PCM format and converting something else to PCM is not a viable option
Does anyone know the lowest current price possible for SanDisk 1TB Extreme microSDXC?
