I interpret the spec sheet as neither being waterproof. The word Waterproof is a section heading and inside that section is a - where there would normally be IPX something
Just let run as it needs 200 hours 4.4mm and 200 hours 3.5mm before it even sounds normal, then it will continue to continuously improve. It needs to have IEMs plugged in to burn-in.
It will also be noticeably better when you get to 100 hours. It’s been reported and I even noticed volume sputtering the first 20 hours. The capacitors will continue to stabilize. Cheers!
I am nearing 150 and can definitely say there are qualities to the whole sound that 'settle down' and just sound better. To know that it gets even better is fantastic.
I had about 40 hours on my ZX300, and I plugged it into the electrical outlet with my iems attached to the balanced, turned it up to 50, and let it run for a week on a loop. After that, I had over 200 hours on it, and I didn't hear any difference. Not quite sure why, as I realize my experience was contrary to that of others.
The TA-ZH1ES sounds really intriguing from everything that I'm reading about it.
What cable is it that is used to plug the WM1A into the TA-ZH1ES?
also, my guess is the TA needs to be plugged straight into the wall, and not into an extension cord/surge protector, correct?
thanks.
As soon as I solve my 2nd paypal account issues.. locked due to suspicious activity. I-ll gwt the most expensive SACDs ever .... japanese remasters from DG
The issue with paypal arose as I created a 2and account with my german bank account, as I had used the email previously with my first paypal account from Mexico
