SONY NW-WM1Z / WM1A
post-15632759
Post #37,996 of 38,958
Mindstorms
Formerly known as Midnstorms
is there any indicator that your 1A is currently running a modded version? seems like the device itself still registered it as 3.02 version
Best way to be shure its just to reinstall 3.02 stock
Reactions: TheThingGoesSkrrr
post-15632769
Post #37,997 of 38,958
Mindstorms
True. I like hearing into my music, Dynamic Normalizer makes everything loud, not very good for high resolution music to my ears.
It depends on your setup and iem for me it only works well on certain songs that have very low volume... also gives you slight margin of EQ adjusting.. but yes everiothingyou turn on even drains up battery or degrades resolution...
post-15632778
Post #37,998 of 38,958
Redcarmoose
No there is no way so you have to manully keep track
Though what is that certificate thing now under unit information? Do you get one when you leave your factory region on all regions?
post-15632783
Post #37,999 of 38,958
nc8000
Kalundborg, Denmark
Kalundborg, Denmark
Age
57
It appears when changing to J
Reactions: Redcarmoose
post-15632788
Post #38,000 of 38,958
Mindstorms
I can happily confirm that morgenstern09 work on WM1Az rev. B its very good and i may stick with it for some days Specially On U it sounds refined in did not like other stuff i tested Staging its very good and has crisp highs!
Reactions: morgenstern09
post-15632794
Post #38,001 of 38,958
Gamerlingual
Japan, originally from Los Angeles
I'm thinking at the minimum sometimes just listen to Stock Direct Sound or using the DSEE HX. It does get annoying when adjusting the volume for certain songs, but if that was the intention even with the FLAC or ALAC files, so be it.
Reactions: Mindstorms
post-15632805
Post #38,002 of 38,958
nc8000
Kalundborg, Denmark
Kalundborg, Denmark
Age
57
It was never the intention that all music should be equally loud
Reactions: Steen Pihl and Gww1
post-15632821
Post #38,003 of 38,958
Gamerlingual
As I said, if that’s how the composer wanted the music to be intended all along, then I will take that route.
What volume level are people listening their music to? Somewhere between 60 and 100?
post-15632831
Post #38,004 of 38,958
nc8000
Kalundborg, Denmark
Kalundborg, Denmark
Age
57
With the IER-Z1R I usually use about 50 on high gain and 70 on low gain but some albums (especially dsd) are recorded low so I might raise the volume. Remember that I almost always listen to an album end to end and therefor don’t use dynamic normalizer to keep the dynamic differences between individual tracks in the album. For playlists and random play across many albums dynamic normalizer can make sense and in those situations there is no natural dynamic relationship between each track. But as you said ultimately it is you listening so you should use what works best for you
Reactions: Queen6
post-15632847
Post #38,005 of 38,958
aceedburn
Kuala Lumpur, MY
Kuala Lumpur, MY
Age
46
Website
soundcloud.com
Depending on headphones or iem. But usually my levels are between 65 to max 85. Always on low gain and only dsee hx on standard.
post-15632907
Post #38,006 of 38,958
Gamerlingual
I’m at 70 with DSEE HX on and off every now and then to catch the slight nuances
post-15632928
Post #38,007 of 38,958
Mindstorms
what happends if you connect both SE and BAL at the same time BAL wins right? no dual sound
mortal-kombat-x-ps4-playstation-4-entrega-inmediata-D_NQ_NP_919169-MLA29308803846_022019-F.jpg
Reactions: Layman1
post-15632931
Post #38,008 of 38,958
nc8000
Kalundborg, Denmark
Kalundborg, Denmark
Age
57
post-15632937
Post #38,009 of 38,958
Lookout57
It varies based on the recording. So anywhere from 55-80 on low gain balanced.
post-15632987
Post #38,010 of 38,958
RobertP
True though to me I much prefer to get the dynamic differences the performer or composer intended in a recording, not just everything at the same loudness but if you just play random across a lot of different albums rather than playing a given album in full dynamic normalizer can be usefull as you don’t constantly have to adjust volume manually
Normalizer crush pipe organ dynamic big time when go through my classical records last night.
Users Who Are Viewing This Thread (Users: 20, Guests: 23)
