SONY NW-WM1Z / WM1A
Status
Not open for further replies.
May 14, 2020 at 10:37 AM Post #37,441 of 45,723
I been thru three different leather cases, and currently using this one,
with a nice hard case as well (which also hold the cable):
I needed this protection for my rock heavy 1z..
I was actually able to shove this in my front pocket!
Edit* I will try to find the links:
Here is the
Hard case
It's hard to find the leather case when it's discontinued and available in other places,
Can you say what the black leather case is called, where you got it, and maybe a link to it? And also the same for the hard case that also stores your items? That link you provided isn't working. Is it the same as this one? https://www.amazon.com/Durable-Tough-Carrying-Storage-ZX300/dp/B07ML7B3GQ
May 14, 2020 at 10:50 AM Post #37,442 of 45,723
AliExpress for both:
But can't find the case now.
May 14, 2020 at 10:51 AM Post #37,443 of 45,723
May 14, 2020 at 10:55 AM Post #37,444 of 45,723
Ok, I found my leather case on Amazon as well:
Here is fixed link.
I used to own the more expensive thick Dignis case, but I didn't like the face exposed, so I got this one.
It was good coverage on the corners, which other folding types did not have (like the one with the stand).
May 14, 2020 at 10:58 AM Post #37,445 of 45,723
Here is link.
Thanks, that one is a definite possibility for me. I'd immediately get the Dignis if they still had it in this color, which I'm told has since been discontinued:
https://www.ebay.com/itm/262872714687
May 14, 2020 at 11:01 AM Post #37,446 of 45,723
That's the one I had.
Found if you clean it with wet wipe, the ink rubs off a tiny bit each time.
Otherwise it's a really thick strong leather case, and very tight fit!
PM me if you want my used one.
I have to find it though..
May 14, 2020 at 11:10 AM Post #37,447 of 45,723
I just did, but also found it via the link below. I can't tell if that site is legit or not though. Ink rubbing off? Maybe you used an alcohol-based wipe? Might be why Dignis explained to me that the current version of their cases for our DAP is an "updated" model..
https://www.jmrsanaie.com/index.php?main_page=product_info&products_id=161989
May 14, 2020 at 11:18 AM Post #37,448 of 45,723
Here is fixed link.
+1 for this case. I have the light brown color, plus they can add your name/initials to the case.
May 14, 2020 at 11:32 AM Post #37,450 of 45,723
Bloody hell, was supposed to take delivery of MDR-1ZR's today, but package delayed due to "exceptional demand" by the courier :poop::poop::poop:
133 hours but-in so far on the single-end, will have to go through it all again with the balanced...
Question: the Dignis case, where can I get this from (in Europe), I'm not getting much luck searching on Google?
May 14, 2020 at 11:39 AM Post #37,451 of 45,723
Cool, does the WM1A fit into the dock with the Dignis on? Do you have a link to the dock btw?
It barely does and leaves a mark on the back of the case. I ended up taking the case off when it's in the dock and put it on when I take it out.
May 14, 2020 at 12:04 PM Post #37,452 of 45,723
The combo of the WM1A and the Z1Rs must be pretty amazing, huh?
May 14, 2020 at 12:07 PM Post #37,453 of 45,723
There have been consideral improvements since those Firmwares.
Hmmm, I'm going to have to try that region again..
I think both ZTAZ1 and ZTAZ1x2 sound better.
A bit more resolution and solidity around the body of the instruments, and more open, with the ZTAZ1x2 a tiny bit more intense/forward, which works with headphones to be more lively.
I tested and noted these aspects with the HD800 (works at max volumes).
I am a 1z user as well, and I found the latest two firmwares, ZTAZ1 to be the best so far.
Before that I considered the ones in @morgenstern09 signature links best.
This is a problem or miscommunication.
I checked the data.
Elna doesn't make anything other than the 47uf that will fit in the Sony.
So it may be just the 47uf in the center board, and then some other mix of cap choices for the other positions.
I'm gonna try that ZTAZ1 mod in the next hour. I will post my thoughts.
Status
