Mindstorms
Formerly known as Midnstorms
- Oct 24, 2016
Ok thank you!
You're welcome - If you click on 'reply' on the right side underneath the person's post, it will quote their post then show up in their notifications, then if you require a response to a question you will get their attention and a quicker reply. Good luck with the battery reset, let us know if you succeed.Ok thank you!
Thanks mate Tried both of them Vinyl sounds just like it should That warm and rich sound of vinyls with good detail retrieval and deep bass I like this as it returns the warmth to the 1A and makes it sound almost similar to 1Z The classical version still has slight warmth, but the detail retrieval is more and i heard some artifacts in the recording Bass is not as deep here and treble is heightened a little Depending on your gear, classical can sound a bit harsh maybe Vinyl sounds very smooth all roundI have two firmware for WM1A that work very well. Both of them have silky smooth, warmth, very good resolution and dynamic.
Vinyl tune is an inspiration of firmware v1.2 and v2.0. If you missed how they sound before then give it a try.
Classical tune is updated. Very resolved. Retrieved every little tiny spat of details very well when tested with my gears. Instruments sound more believable.
Sorry no 1Z version yet! Will be done soon.
Make sure you are on fw 3.02. The link is >> Here
Thanks for feedbacks. Will keep this in mind for later on.Thanks mate Tried both of them Vinyl sounds just like it should That warm and rich sound of vinyls with good detail retrieval and deep bass I like this as it returns the warmth to the 1A and makes it sound almost similar to 1Z The classical version still has slight warmth, but the detail retrieval is more and i heard some artifacts in the recording Bass is not as deep here and treble is heightened a little Depending on your gear, classical can sound a bit harsh maybe Vinyl sounds very smooth all round
Which is your favourite among these 2?Thanks for feedbacks. Will keep this in mind for later on.
Vinyl is doing very well on my more energetic /north of neutral bookshelve speakers too. Similar type of headphones and IEMs will benefit from this also. I got goosebumps when hear solo electric guitar and violin. Flutes, horns and saxophones tone are all their similar to 1Z counterparts.
I’m testing vinyl on my Z5 which has superb bass. Plays well. Bass not boomy but punchy.Thanks for feedbacks. Will keep this in mind for later on.
Hard to pick for my IEM. They both good.Which is your favourite among these 2?
I have done it with my modded 1A with over 4800 hours play time. Seems work with better battery life but I have not scientifically measured it.so has anyone experienced battery reset? and being blessed by it? im doing one right now.. so im curious
do you like plug ins? i guess not right?
On the other hand , MB is fully featured, you can browse your music virtually by any tag, including. Composer. Has many settings and skins. You can even point to the encoder to use when ripping, it can even convert between formats. And super useful you can customize for each device how it will transfer. I had use for both walkman and SD card MUSIC\<Composer>\<Album>\<Track> - <Title>Musicbee may be a bit difficult getting used to. One caveat I found it.that it would duplicate albums (in total albums count) if.you chose it.to split by Artist (unlike MesiaGo it merges albums with same name and uses VA as artist). Other caveat I didn't get fully around with MB isthe creation of a Hi-res Audio filter/view
Despite the unfortunate occasional in-fighting
However, would draining it to zero again be detrimental to the battery?
Or it's fine as long as I don't drain it to the point where the 'battery needs charging' icon no longer appears?
Well, no fighting initiated from my side, as you can all see for yourself.
Let's not go back there lol. You (and others) have made huge contributions to this thread, and I'd rather focus on that
I wasn't actually referring to you specifically anyway, more just a general trend.
It's something that happens on most threads from time to time.
Sometimes people get into arguments over stuff, but that happens in real life too, and doesn't need to be permanently divisive necessarily.
And there's people who are passionate about the hobby in different ways, so often there's clashing opinions and viewpoints, and communicating by text makes it even easier for friction to occur.
I can't help thinking that in many cases, if the same people who got into an argument on the thread were to have met in a cafe or something, they'd probably get along really well, despite any differences
