when creating playlists for the 1A ... does the text file mu3 sit in the playlist folder itself or do you place that text file in the main music folder in the 1A (so it’s outside the playlist folder but within the main music folder)
You can place them where ever you want to store them as long as the path to the files are reachable from that directory. To be safe I always use absolute paths for the tracks.
While on topic I have recently "dusted" off my 1Z and would like to load it with my files. I am on a Mac and seem to recall Sony's app. not being updated for Catalina?
What is the best and easiest way to fill up a 1tb card using a Mac?
Easiest: Copy it over the USB cable.
Fastest: Get a good card reader and plug it into the Mac to copy.
Most organized including playlists: Use Music.app and Dapper.
(My video here done with an WM1A)
I tried using Dapper but could only get it to recognise some playlists from iTunes... but I couldn’t get them to work on my Flac or DSD files/folders....
The WM1A would recognise the playlists but would show no music in the playlist.
I also tried doing the text editor that was explained on here but again I had no luck..,
All my music files were formatted/ tagged using Picard ...
So I found an app called M3Unity which I tested using its free download and that worked perfectly... so I bought that app for $5 and I just drag my folders into its window... and it transfers all the music into the app... I can then move files about and also create hierarchies for individual titles..,
I then saved the work I had done and it was recognised on my WM1A... so I now have all my playlists appearing in the playlists option on the WM1A...
The only small issue was that the app copies a new folder... so it copies a new lot of my music in that folder, which takes time so I now have the original music folder open... I place all the music files in the trash and I click save on the playlists app... so the app then creates the playlist m3u file and then I get an error message saying it cannot save the music so I close the app and select undo from edit tools and the music is removed from trash back to the original folder which also has the new m3u file... so that saves me replicating my files and also saves me the time it takes to do so...
So now I have my playlists using the same tags etc I was using before...
