nanaholic
- Sep 2, 2010
It has over the years with almost all players I’ve encountered where you use the hadphone out as a line out been the standard recommandation to use the highest possible output on the player and then use the external amp for volume control
Old folk wisdom is not always correct. You update your knowledge when new information is available.
If you just go see actual measurements of even TOTL players, maximum volume always introduce a bit of distortion. So it can't be good advice.
Also I know Sony engineers says for their device - even their most high end DMP-Z1, high gain is a bit more course and less ideal than normal gain which is why they always recommend using normal gain unless you are driving a difficult load and you REALLY need that extra power.
