nanaholic
- Sep 2, 2010
Nanaholic,
You are my hero, so save me again.
I never changed from Media Go, so I decided to make the plunge after looking at the last comments.
Now that I switched, /i have albums missing artwork, missing albums, do I have to go thru my entire library to fix?
Thanks,
Embedded album art from Media Go should just show up on Music Center, unless you have files which don't support album art like WAV files.
Media Go is similar to iTunes in that it also stores album art on a separate internal database, so even for formats which don't support it it will show/remember artwork, but as far as I know Music Center doesn't do that now. On the other hand Muisc Center now has the ability to fetch album art work off the internet for any files that are in the library if you go into the file tag properties (whereas Media Go only allows you to this for CD ripping), so you can try this feature and see how that goes.
