I thought it only add noises ?
No.
Vinyl Processor “recreates the warm, rich playback of a record on a turntable.” And does a mighty fine job at it, least I think so.
Only thing i wish is that they left more control in the bass region, the job they doned its awesome but i miss some of the dark character of 2.0 firmware agree that its like having two daps they could let the user have a little more control over the dap to finally recreate 2.0 warm sound with loads of bass.. and of course even get to 1.2 with the sacrifice of stage if necesary thats my 2 cents...If you go to the Vinyl Processor setting in your DAP it says that it changes the sound sig to the "warm, rich playback of a record on a turntable". In other words it changes the sound of the WM1A to polar opposite characteristics. It's like having to two DAPs in one. Sounds like a more refined ZX2.
Does anyone use mp3 files at 192 kbps using wm1z? If so, how do they sound? Any recommendation?
Are you On 1Z? also what volume via SE right?I personally prefer 'Direct Mode' I use Shure 846's mostly, they have ample amounts of bass. I really love their sound signature with the WM1Z. I also Like the vinyl processor on some album.
Is there any programs out there to embed cover / folder .jpg into the metadata and free? Unless if I'm doing something wrong wm1z doesn't pickup cover.jpg / folder.jpg so a lot of album artwork is missing for me.
Is there any maximum resolution for embedded album art to display in 1a
thanks, but this isn't exactly automatic unless if i'm doing something wrong. I can only do one album at a time and appears I can't do multiple abumbs? id on't mind selecting which item when ithas multiples, but I have to scan one, delete that off the list, scan again, delete off list, repeat.Mp3tag will do it. Also your jpg files have to be baseline as Sony can’t handle progressive jpg
You can do batch processing
ThanksNo. Just can't be progressive jpgs.
