BlueThunder
Cheers. I was actually just watching this video, which says the same around about 7:40:-Not sure whether it’s advisable to use an unbalanced cable with a balanced output via means of an adapter. The other way around is ok (balanced cable to unbalanced output).
This is what Moon Audio say on their website:
For example, If you use an adapter cable from a female 1/4" or 1/8" headphone jack to a balanced 4 pin XLR and connect this to a Balanced amp you are essentially shorting to ground 2 legs of the circuit making the amp single ended. This can also potentially damage your balanced amp depending on the design. I can't tell you how many times we have been asked to make such an adapter and we explain the situation and then are told how this adapter can be purchased on Amazon. Why are companies selling it? One word. Greed. I would highly recommend not using these. A very common adapter cable used for this is with the Astell & Kern 2.5mm TRRS balanced output. Astell & Kern has explicitly stated this will damage their DAPs. Don't do it, its not worth it. You can convert a balanced connection back to single ended. This is not a problem at all as long as your main headphone cable is balanced, then you can add an adapter cable. For example, we make adapters that convert the Astell & Kern balanced 2.5mm plug to a 3.5mm plug for use with your phone or another device that only has a 3.5mm or 1/8" jack.
https://www.moon-audio.com/single-ended-versus-balanced-connection
I guess I have to stick to 3.5 then. Unless it is worth getting a 4.4 balanced to single ebded, then use adapter.....
