you can use Music Center app, it will detect it automaticallyOmg Omg. Just found out about update how do I update?
SONY NW-WM1Z / WM1A
- Thread starter leylandi
- Status
- Not open for further replies.
NaiveSound
- Nov 8, 2015
I found a link Redcarmoose added and I'm just installing it raw. I don't like bloatware apps. But thanks I appreciate youyou can use Music Center app, it will detect it automatically
NaiveSound
- Nov 8, 2015
I wonder how the sound will be. Hopefully not too compromised. Real happy with the sound I have now (pre 3.0)
NaiveSound
- Nov 8, 2015
Omg love it still not as warm but that's ok. Feed me the details more. Treble is better than previous version.
But bass is not as pronounced
Bluetooth works great this is sexual!
Now... So I keep my phone volume at max while it pushes over Bluetooth? Or does that not matter? For best quality over Bluetooth? (while I wait for my USB cables to come in) haha
tonehk
- Jan 31, 2009
Can someone check if you use this as a usb dac whether it can process mqa tidal?
Thanks
Thanks
rabidsquid
- Jul 8, 2008
Thanks
WM1A seems to read PCM 48 kHz regardless of hifi or MQA track. This is with option set "passthrough MQA" turned on in Tidal.
captblaze
I have tidal MQA passthrough set to off and it reads PCM 98kHzWM1A seems to read PCM 48 kHz regardless of hifi or MQA track. This is with option set "passthrough MQA" turned on in Tidal.
gerelmx1986
Hey @nanaholic what settings do you use in music bee for the USB driver so it can output DSD and correct PCM data f.e if i play a 24/96 it outputs currently 24/48
alphanumerix1
So the wider soundstage people are claiming is that se or bal or both?
Anyone with 2 wm1a? Test 2.0 vs 3.0
quan61092
- Jun 20, 2016
after upgrading to 3.0, my bal output... deaf right side....
but right side still sound if i pull the jack a little bit off, and i use 2.5 to 4.4 adapter (i pull the 2.5 jack off)
i dont know, maybe sony change the configuration of the balance output :-?
please help me, or give me firmware 2.0, if u still have it
alphanumerix1
@twister6 v3.0 impressions soon?
gerelmx1986
you can remove the embedded cover files form files using mp3tag and export a single picture witht he folder name under quick actions
https://www.head-fi.org/threads/sony-walkman-tips-and-tricks.759006/page-9#post-14521182
Stealer
- Jun 7, 2011
hi, I kind of late here so if you can pls direct me a link or explain what is these 2 functions for.
And what is needed to enable them or use them?
I really have no idea here..
"The Bluetooth Receiver & The USB-DAC functions have been added."
thanks
thanks
NickleCo
Previously known as DatDudeNic
- Apr 14, 2016
Im using the stock btg starlight cable since I like its bright naturei am sold , as we have the same setup (zeus +wm1a) , what cable do you have on zeus ?
nanaholic
- Sep 2, 2010
Can't help you I don't use MusicBee for playback only file management.
- Status
Total: 21 (members: 0, guests: 21)
