- Oct 14, 2013
Don’t worry, there are more, like Z1R, ier-Z1RI love how the z5 pairs with the WM1A, with nice minds and high details and nice bass rumble
1) male 4.4. TRRS to AES/EBU male --> WM1A female 4.4 TRRS to female AES/EBU (Gustard A20H)
Will be emulation. 20 games installed on a flash rom. Mostly Linux, some crappy shaders for upscaling and a nostalgia infused menu. Nothing else.
No, AES/EBU is a digital signal while 4.4 TRRS is only analog. However, when the next firmware is releases for WM1a, you can connect it directly to your PC and it will function as a DAC and stay charged at the same time.
I am not technically inclined when comes to all these. Thanks. That;s what I am afraid of.
What about this? 4.4 Bal to 4-pin XLR Bal. i can use that to feed input directly to headamp. AFAIK, XLR is analogue
https://www.amazon.com/Balanced-16c...coding=UTF8&psc=1&refRID=9WF4HTNTT3KKQXHFM9V0
if above still doesn't work, i guess the last option is to use 4.4 out to RCA .
Thanks a lot for your patience. Learning the ropes here.
Cheers
I noticed the adapter you linked to is a female 4pin xlr. Wouldn't you need a male, as I would guess you amp's inputs are female? These adapters you see usually are intended to be used to allow your headphone cables to be used with different output jacks. Sorry if I'm off base from what you're trying to do!I am not technically inclined when comes to all these. Thanks. That;s what I am afraid of.
Cheers
You are right, the amplifier usually and as a standard, always have female input, and is XLR-3 female, and not XLR-4 female. You will need something 4.4mm male to dual XLr-3 Male to connect your WM player as an analog source into your big amplifier .I noticed the adapter you linked to is a female 4pin xlr. Wouldn't you need a male, as I would guess you amp's inputs are female? These adapters you see usually are intended to be used to allow your headphone cables to be used with different output jacks. Sorry if I'm off base from what you're trying to do!
You are right. Oversight. Seeing what @Whitigir said, look like I need to custom it. Pity I am not in States.I noticed the adapter you linked to is a female 4pin xlr. Wouldn't you need a male, as I would guess you amp's inputs are female? These adapters you see usually are intended to be used to allow your headphone cables to be used with different output jacks. Sorry if I'm off base from what you're trying to do!
Is it electronic like *chill house/chill techno*? I love that genreThis music is so incredibly relaxing.
Did you ever get your answer??Can 1A drive ve zen 2 SE ? I need a earbud to listen when im sleeping, my bad habit .
